mm I think that was optional. he's user id is Abe2 send him an email. Or see if ScottyM35 have some thing invented.
Thanks Stao. :)
I do an 80mm alloy intake kit to suit the stock airbox with bov and breather fittings.
That 80mm one would it suit a atr43g3 ???? I want something that would allow standard air box connection with plumb back for both retic and oil breather
Get scotty to make one for you then.
It would suit the 80mm
Its been made 4inches for a reason. Best to have a 4inch intake pipe.
Also I've got a R33 turbo sent in for high flowing about week ago, job is complete, but it has no name or return address on it. Please pm through if that belongs to you.
Ok than can anyone make one up four inch and reduce to 3 inch ( Scotty ). It has to be three for the afm
I'm sure Scotty could do the same design in 4", PM him to discuss it.
Like you said, you are running an afm like a z32 in the standard position, so your intake will have to be 80mm at some point to be able to connect the afm.
Just get a 4" to 3" silicone reducer for one end of the intake.
Edited by Mitcho_7
It's been made 4 inches because of the anti surge ports, not because it needs a 4 inch intake. While 4 inch would be good there is no point if you still run the afm. Mine has run 350kw on a 70mm internal pipe so this one with a 3 inch internal should be no problem for most customers.
I can make any piping you need but I would need the car here obviously.
Do the g2.5/g3 have 4" intakes? I always thought they were 3"?
G2 is 3 inch I can't say about g2.5 but g3 is definitely a 4 inch intake that's why it needs the spacer on the manifold
Anyone ever tried putting a pod in stock air box with the arse cut out?
Whats the point?
Just chuck a high flow filter on there and enjoy.
Or do you want induction noises ?
With Hi flow panel filter and a metal intake pipe I get a sweet induction noise, you don't need a pod for it.
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
