I've converted last run into actual torque based on the traction effort listed on the reading.
the new SS1PU is also built, hopefully due in for a tune next week. The current agenda still lays on the design of the actuator and waste gate package, as I'm hopping it holding 20psi flat internally gated. Likely will need designing and making of a new CNC billet actuator some how allowing spring tension adjustments like few of the external wastegates in the market.
Since many recent results from Status were done on e85, I will likely be running the same fuel for the coming tests making the result comparable. Having said that, I will get some 98 runs done on same or different dates, depending on their time allocation.
I would like to see some results of the new ss2 on 98 running about 18-20psi when you get the chance stao.
Was the graph for the e85 run fully finished or was it starting to lean out so you left it quite safe up top?
Also, I thought you always said the ss2 was better as an external gate only turbo?
Edited by Mitcho_7
thought about it. Ordering couple hopefully this week. How ever back pressure between setup varies, So it would be ideal been able to adjust the spring load freely referring to each and every setups. I will put some thoughts into making it.
Ahhhh fark it, after some thought and Stao's advice I have sent my SS2 to be updated like the new one.
If they both make similar power and new wheel with .82 housing makes similar response to old wheel with .63 then will be good if it ever hits the track.
Looking forward to Stao's results on 98 later this week also
Are you going to run it on internal or external gate?
I'm keen to see if the 98 results for the ss2 show the same improvements over the g2.5 as it did on e85
I've got my ss2 0.82 and an external 44mm tial gate dummy fitted at the moment to get my ext gate pipe cut to correct angle and length etc. So will be install properly and running by next Saturday. And may I say its going to be a very neat setup
Stao, can I come in for the free upgrade of the compressor wheel before I use the Turbo? And will the lightness sacrifice strength at higher boost levels? And is the blade design changed or just thinner blades. Any other major changes?
Internal gate. Ported stock manifold. Heaps of head work. Tomei springs and poncams
I'll be very interested to see what the common models can do on high mount externally gated setup.
Its going to make a differences compare to stock manifold on internal gate, you usually find a responsive externally gated turbo perform poorly running internally gated as the combination of the charger is different. For a internally gated turbo to keep on making power the EGT has to stay low, which the only way for it to happen is go larger in turbine housing or a more free flow turbine wheel, then compensate response with a lite weight, small but very efficient compressor.
I will be concentrating in up to 300rwkws pump 98 bolton turbos and probably up to 350rwkws external setups. I'm in the process of making a full bolton kit including manifold, gate, turbo and full 4 inch front pipe with Brea Autos. And will post of what we can come up with.
4inch pipes nice but the afm has to be relocated and what do u do with the 2X breather holes- BOV return and the oil vapour return pipe?
I actually mean 4inch front pipe as in from turbo to the cat, I will get a custom 4inch exhaust made up as well. So basically the full bolton kit including: Intake pipe, turbo, manifold, external gate, and full exhaust. I will see if I can make a heat shield that hides most of the stuff.
I re-read your last post and now understand what Ron was asking about. Ignore my jump to conclusion.
On another note I need to find a tuner for when my cars ready as Xspeed is shutting shop.
Results from the newer SS2 prototype on Pump 98 internally gated in bolt form. It made final of 302rwkws and did actually manage 200rwkws by 4000RPMs. Pretty sweet to drive on road. At this stage that every HP its getting is based on a trade off of some response. Probably only a tinny bit more room to play with. I will trail one more wheel on it in about a week time.
Looks good Stao. Any idea on where the pricing is going to start for the packages?
No plans for a manifold + int gated turbo package in the works with brea? I'd be interested if there is
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
