have you/ do you intend to run and atmo bov? If so, go the MAP sensor route.
On a side note, can the adaptronic have duel maps/flex fuel setups?
Edited by Mitcho_7
Yeh. The adaptronic supports flex fuel by interpolation of fuel consumption. That's what the manual said anyway
But not sure about 2 separate maps.
Yep you can setup it to run flex fuel and switch maps.
Could something be restricting my setup do you think guys? Seems odd that's now 2 guys making more power then me on a lot less boost.
I understand different dyno etc etc
But just wondering if anyone has any opinions?
Tis decent compression, maybe look at the cooler like was suggested
Did Jez drop the exhaust at all to see if it was causing a restriction or were you pressed for time?
Edited by Mitcho_7
Finally got mine SS1PU tuned. It made 255rwkws on 16psi. Dame responsive to drive. will upload sheets later when I get a scanner.
nice result mate, congrats
Z32 AFM
3 inch exhaust (decat)
555 injectors
SS1PU
Nistune
3 inch intake
Splitfire coils
Hybrid front mount
Umm have I missed anything
Mine has:
3.5 inch exhaust (decat all the way though)
550c injectors
SS1PU
Adaptronic plugin (Used to have a wolf 3D)
3 inch intake
Splitfire coils
Unknow cooler came with the car.
The best run was 261rwkws when car's cold, and average is 255rwkws after couple of runs. sheet is attached.
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
