OH. I missed the bit where you edited my post.
IMHO difference will be next to zer0. All assuming the IWG isn't actually hindered by reducing it to a V-band out.
If the drain pipe is of concerns I would heat wrap the dump and put reflective race tape on the drain hose.
IMHO difference will be zer0.
Done already and so far so good. It's also to lowest part of my exhaust so was thinking about modifying it to be higher or make a dump in v-band and sell my bell mouth. Might just leave it and modify from dump backwards
So you not going to test the stainless mani remade in steampipe first before delivering a verdict?..i thought it would pick up
spool made in steampipe due to retaining heat better?
cheers
darren
I think you would find the stainless would retain the heat better than the carbon steel :)
Also thinking about this. Following the recent discussions on the JJR bellmouths not matching up to the gasket and possibly being a restriction, I decided to pull mine off to double check and low-and-behold, mine is the same. I could clean it up with a die-grinder, but I'm considering just having a custom dump pipe fabbed up, possibly in 3.5 or 4".
Stao, how hard would it be to convert the G3 Type-A rear housing from the OEM 6-bolt pattern to a V-Band or even 5-bolt flange?
Keep me in the loop if your going to get one made. Stao wants a photo of mine when I'm home to confirm rear housing model. Hopefully can just bolt on the rear adaptor
I ground mine out a bit and tapered the edges but still not 100% happy with it. It also has an inner skin that has lifted in sections prob due to the 1000c + temps it saw 4 years ago when it Chernobyl'd
Edited by t_revz
I also run a JJR dump and was very disappointed in the way it was when it arrived, I ended up die grinding massive amounts of metal out of it and had to reweld the flange as the pipe is welded inside.
But either way the car is going great with the high flow, I've done the first drift day in it (well 2 days, qr drift matsuri) and survived, even drove too and from the track :)
For a budget style drifter the high flow is perfect, I'm running stock injectors and around 210rwkw at 14psi.
The turbo and engine performed perfectly all weekend, and only problem was fuel surge on big right hand corners in third (surge and pump currently being fitted) and also killed my diff lol
Massive thanks again to stao
Anyone with an xforce dump want to compare for gasket match sake?
If we can identify a better dump stao won't need to make new rear housings for everyone
Well when you all get ready to sell your JJR dumps, someone PM me... I need a cheap dump...
Just saw they are only 180 in mild steel or 200 in stainless from just Jap. Cheap as
I won't feel bad hacking mine up now. Might cut a new flange at work and transfer it over
i think stao should offer his own dump to suit his own rear housing
then develop an iwg setup that works really well
if he can make a turbo for $1k then he should be able to knock out some cheap dumps
If you're gonna change the dump/flange pattern, you may aswell follow through, do it properly, and go external gate.. F*ck it, why not get a 6 boost while we're at it..
Perhaps this is why Stao makes these turbo's the way he does (Affordable and simple).
^ Exactly.
One of the best things about a HG is that it bolts on and is zero hassle.
Photos of Stao's adapter next to an OEM gasket shows his machine work is second to none and is as good as it can get in terms of being matched to the gasket. You cant ask for better.
Now that we know that JJR quality has gone down hill for the 1 piece dumps all we need to do is find an alternative. My money is on the Xforce.
^ Exactly.
Mine is 3 years old now, so I wouldn't say it's a thing that has happened recently.
Why does changing the flange pattern mean you should go external gate? I don't see how it makes anything harder? Right now you buy a HG turbo, and it's pretty much a requirement to have a dump pipe as well if you want the numbers. So you need to buy a turbo and a dump in either situation, why is it any harder to have a different flange if it's coming in a package?
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
