My turbo turned up while I was away at work, didn't even know it was on the way :P
Thanks Stao for all the help you've given me through this process, turbo looks good and can't wait to see how it goes. Now just have to finish my engine
I only have the standard highflow which is good for 430hp.
270x1.34= 361rwhp
361*1.2=434 engine hp allowing 20% drive train loss (which is a widely accepted rough estimate)
Yours sounds about right,
Is that v-band???
V-band rear? yes
3.5" V-band
I will take some more photos in a minute, that was just a quick camera phone photo last night when I got home from work
Very nice looking turbo, Not sure if I want to paint the housing or not lol
No im just wondering,
anyways i got it retuned this morning again and because of timing and it was sort of pinging my tuner had to back the power off, now its on 255kw on 18 psi, i'll post the final tune tonite when i got a chance, im happy with the turbo either way.
V-band rear? yes
3.5" V-band
Very nice. I need one of these V-Band rears :woot:
That was my ceramic roller bearing highflow with a .60 comp housing :yes: and new externlly gated through turbine housing.
its pretty interesting seeing the 6boost's manifold has very long runners. any one can share some theory in doing that?
Equal length runners and merge collected so exhaust gas gets to the Turbo in equal/even bursts isn't it?
Pretty keen for this engine, really hope I can get the ext gate to work but think life won't be so bad if I have to go int gate I don't think
Need to trim the Turbo studs as one of them is fouling but other then that I'm very happy with how its looking :)
V-band rear? yes
3.5" V-band
Prob just me or the photo but v band doesn't look 3.5".
Plus I thought Stao told me once he could only do 3" max.
Hi Stao,
Long time no speak! As you already know, I'm currently running a top-mount Garrett GTX3076R but looking to return the car to stock-ish to sell and was wondering what the boost response is for the hi-flowed R33 standard turbo and the hi-flowed R34 turbo like compared to the stock R33 turbo.
    • On the hot side pipe work, or if you want to compensate for pressure loss from the IC, post intercooler on the cold side, pre-throttle
    • They're notoriously difficult if you traverse forums... the 102TB and FAST102 are so bad that most people actively don't buy it unless they REALLY want that extra 1hp. The idle stuff isn't really that hard. The cam is pretty manageable and while it acts like a larger cam the whole car actually drives smoother than before. I like to just tinker so if I can get 50rpm less variance or rule out situations where it does 'unexpected' things it's fun for me. HOWEVER If you just let a tuner give it a guess for a couple of hours and had no way/desire to test and tweak it yourself you'd spend a lot of money at the tuner or be pretty frustrated, that's for sure. But yeah. Drives great. (then I drive partner's Civic Type R and I think.. well, more tweaking to do) But for what it is (cam, TB, intake, manual etc) it does commute around really great once you figure out how the idle tables and GM's systems intend to work.
    • I usually source pressure on inlet manifold after throttle body
    • Where is the best location for boost pressure source when running mac 3port boost solenoid?  my new turbo does not have a fitting for that on the compressor housing.  how come Garrett make a turbo without that?  im confused
    • From my memory, which isn't that great, we did have issues getting the large throttle body on my old LS1 to play nicely at idle, first it would stall, then it would only idle at 2k rpm, then it would hang at 2k rpm for a few seconds and then drop and stall, then, finally, the best we got was it would hang at 1.5k rpm for a few seconds then drop to around 800 rpm The tuner stated that large cable throttle bodies are a PITA, and if I wanted anything better than what we ended up with I would need a electronic throttle body and all of the aftermarket ECU stuff to run it
