My turbo turned up while I was away at work, didn't even know it was on the way :P
Thanks Stao for all the help you've given me through this process, turbo looks good and can't wait to see how it goes. Now just have to finish my engine
I only have the standard highflow which is good for 430hp.
270x1.34= 361rwhp
361*1.2=434 engine hp allowing 20% drive train loss (which is a widely accepted rough estimate)
Yours sounds about right,
Is that v-band???
V-band rear? yes
3.5" V-band
I will take some more photos in a minute, that was just a quick camera phone photo last night when I got home from work
Very nice looking turbo, Not sure if I want to paint the housing or not lol
No im just wondering,
anyways i got it retuned this morning again and because of timing and it was sort of pinging my tuner had to back the power off, now its on 255kw on 18 psi, i'll post the final tune tonite when i got a chance, im happy with the turbo either way.
V-band rear? yes
3.5" V-band
Very nice. I need one of these V-Band rears :woot:
That was my ceramic roller bearing highflow with a .60 comp housing :yes: and new externlly gated through turbine housing.
its pretty interesting seeing the 6boost's manifold has very long runners. any one can share some theory in doing that?
Equal length runners and merge collected so exhaust gas gets to the Turbo in equal/even bursts isn't it?
Pretty keen for this engine, really hope I can get the ext gate to work but think life won't be so bad if I have to go int gate I don't think
Need to trim the Turbo studs as one of them is fouling but other then that I'm very happy with how its looking :)
V-band rear? yes
3.5" V-band
Prob just me or the photo but v band doesn't look 3.5".
Plus I thought Stao told me once he could only do 3" max.
Hi Stao,
Long time no speak! As you already know, I'm currently running a top-mount Garrett GTX3076R but looking to return the car to stock-ish to sell and was wondering what the boost response is for the hi-flowed R33 standard turbo and the hi-flowed R34 turbo like compared to the stock R33 turbo.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
