Stao tried to seach and find the answer because I think you have told me before.
But what do you think the limit of the SS1PU would be on water meth injection.
Mine was limited due to the heat.
So in the future once I save the dollars I will be going that route.
But at the same time dont want to find it hits a wall at like 260rwkw
The R33 highflowed turbos would support up to 240rwkws while R34 turbochargers can be high flowed to support 260rwkws. response wise high flowed R33 turbo is about 300RPMs earlier. Personaly I prefer to run a highflowed R34 turbo
Actual water meth (50/50ish mix) will get you results similar to E85 if implemented right.
Yet to see any E85 results on the ss1pu
If you know of any then I would love to see.
Just want to know what to expect if I do it
Prob just me or the photo but v band doesn't look 3.5".
Plus I thought Stao told me once he could only do 3" max.
I thought it was 3.5" cause we were talking about a 3.5" dump. But if its 3" im not worried, makes it easier to get the dump to fit to the turbo anyway
Based on the spec of the thing it will lay close to 300.
I'll give you a good deal on my WMI kit if you want to be the first to try. Not trying to be a viral sales kent.
Pm me prices and details of the kit
Don't know to much about them but would need one with a good fail safe
I fitted one to an M35 in the stock housings that managed 300, not a good indication of what it would do on an RB but it should be close.
Good to know Stao has done a nice job with the turbine side of things. I can't wait to have mine running :)
How did it go on the VQ?
Still means it can flow that sort of power
Spoke to my clutch guy today and his going to get back to me if it can handle that power.
If it can't then I can't afford it
If it can then I will be doing that over Christmas
When in for a return tune today.
After a few runs the manifold pretty much overheated and split one of the silicon hoses so had to call it a wrap again.....
We got up to 283 rwkw before the silicon hose split
Tune as it stands atm:
I might try out one of staos dual actuators as its at 19.5 psi dropping to about 15.5 psi i think
What turbo is that Tony? Is it stock intake mani?
Cheers
Justin
Hey Justin its an internal gate ss2 turbo on 98octane
I got a one of staos china manifolds
It moved nearly 2 ton down the quarter in 12.9, faster than mine as he gets boost on stall.
I think it hit 20psi by around 3k...
Thats very nice! Theres always a point where you can have a faster car with a lower number, which is something im scared i may have overshot by going the SS1PU on my SR but we will see!
Good to note that the unit is an all round good turbo though. Everyone who has one seems to be happy with it regardless of how much power they made (its only numbers anyway). Props to Stao yet again!
What fuel Tony? Its starting to shape up nicely (ignore the fuel question coz you replied yourself before I hit send)
21U @ 260rwkw on United E85. Only 14PSI as ter rear tyre can't handle more around the track.
This turbo has now done over 40 track days, including WTAC.
Responce..5th gear at 110 is pretty much on boost. Its over 100rwkw at 3000rpm on trents dyno.
Update on car.
Car is finally tuned:
R34GTT
Mods:
SS2 Internally gated Turbo
98 Octane
China manifold
3inch JJR dump & 3inch exhaust
ID 1000 injectors
Yellow jacket coil packs
Hybrid return flow intercooler
Scotty 3inch intake
About 190rwkw at 4,000 rpm so happy with that!
About 20psi falling over to about 16psi i think
Note this is a conservative track tune
    • Hi...a bit a "development" on the brakes. I spoke to the guys where i get brakes from...and they are saying that 296mm EBC are for R34 GT-T. I then went to their site: https://www.ebcbrakes.com/vehicle/uk-row/NISSAN/Skyline (R34)/ and search for my car(R34 GT 1998 - it has GTT brakes) and it show me this USR1229 number and they are rly 296mm rotors... So now iam rly confused... The rotors i have now on the car are 310mm asi shown... So where is the problem? Does the whole EBC got it wrong or my calipers are just...idk know what?
    • Oh What the hell, I used to get a "are you sure you want to reply, this thread is XX months old" message. Maybe a software update remove that. My bad.
    • This is a recipe for disaster* Note: Disaster is relative. The thing that often gets lost in threads like this is what is considered acceptable poke and compromise between what one person considers 'good' looks and what someone else does. The quoted specs would sit absurdly outside the guards with the spacers mentioned and need  REALLY thin tyres and a LOT of camber AND rolling the guards to fit. Some people love this. Some people consider this a ruined car. One thing is for certain though, rolling the guards is pretty much mandatory for any 'good' fitment (of either variety). It is often the difference between any fitment remotely close to the guards. "Not to mention the rears were like a mm from hitting the coilovers." I have a question though - This spec is VERY close to what I was planning to buy relative to the inboard suspension - I have an offset measuring tool on the way to confirm it. When you say "like a mm" do you mean literally 1mm? Or 2mm? Cause that's enough clearance for me in the rear :p I actually found the more limiting factor ISNT the coilover but the actual suspension arms. Did you take a look at how close those were?
    • @GTSBoy yeah sorry i know thery are known for colors bud those DBA are too in colors 🙂 Green will be good enough for me
    • That's my life. Past-Duncan has a lot to answer for
