Stao tried to seach and find the answer because I think you have told me before.
But what do you think the limit of the SS1PU would be on water meth injection.
Mine was limited due to the heat.
So in the future once I save the dollars I will be going that route.
But at the same time dont want to find it hits a wall at like 260rwkw
The R33 highflowed turbos would support up to 240rwkws while R34 turbochargers can be high flowed to support 260rwkws. response wise high flowed R33 turbo is about 300RPMs earlier. Personaly I prefer to run a highflowed R34 turbo
Actual water meth (50/50ish mix) will get you results similar to E85 if implemented right.
Yet to see any E85 results on the ss1pu
If you know of any then I would love to see.
Just want to know what to expect if I do it
Prob just me or the photo but v band doesn't look 3.5".
Plus I thought Stao told me once he could only do 3" max.
I thought it was 3.5" cause we were talking about a 3.5" dump. But if its 3" im not worried, makes it easier to get the dump to fit to the turbo anyway
Based on the spec of the thing it will lay close to 300.
I'll give you a good deal on my WMI kit if you want to be the first to try. Not trying to be a viral sales kent.
Pm me prices and details of the kit
Don't know to much about them but would need one with a good fail safe
I fitted one to an M35 in the stock housings that managed 300, not a good indication of what it would do on an RB but it should be close.
Good to know Stao has done a nice job with the turbine side of things. I can't wait to have mine running :)
How did it go on the VQ?
Still means it can flow that sort of power
Spoke to my clutch guy today and his going to get back to me if it can handle that power.
If it can't then I can't afford it
If it can then I will be doing that over Christmas
When in for a return tune today.
After a few runs the manifold pretty much overheated and split one of the silicon hoses so had to call it a wrap again.....
We got up to 283 rwkw before the silicon hose split
Tune as it stands atm:
I might try out one of staos dual actuators as its at 19.5 psi dropping to about 15.5 psi i think
What turbo is that Tony? Is it stock intake mani?
Cheers
Justin
Hey Justin its an internal gate ss2 turbo on 98octane
I got a one of staos china manifolds
It moved nearly 2 ton down the quarter in 12.9, faster than mine as he gets boost on stall.
I think it hit 20psi by around 3k...
Thats very nice! Theres always a point where you can have a faster car with a lower number, which is something im scared i may have overshot by going the SS1PU on my SR but we will see!
Good to note that the unit is an all round good turbo though. Everyone who has one seems to be happy with it regardless of how much power they made (its only numbers anyway). Props to Stao yet again!
What fuel Tony? Its starting to shape up nicely (ignore the fuel question coz you replied yourself before I hit send)
21U @ 260rwkw on United E85. Only 14PSI as ter rear tyre can't handle more around the track.
This turbo has now done over 40 track days, including WTAC.
Responce..5th gear at 110 is pretty much on boost. Its over 100rwkw at 3000rpm on trents dyno.
Update on car.
Car is finally tuned:
R34GTT
Mods:
SS2 Internally gated Turbo
98 Octane
China manifold
3inch JJR dump & 3inch exhaust
ID 1000 injectors
Yellow jacket coil packs
Hybrid return flow intercooler
Scotty 3inch intake
About 190rwkw at 4,000 rpm so happy with that!
About 20psi falling over to about 16psi i think
Note this is a conservative track tune
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
    • I believe @Duncan has given it a crack at Mt Buller before (in actual race conditions)
