That is a cropped version of the TD06 turbine, that would shift power band to mid high range.
Not what what I meant. Different people call teh different wheels different things.
What is the difference between the Greddy T67-25G and the Greddy TD06H-25G ?
TD06H
A T67-25G (on the left)
Its not simply a cropped wheel. Its 11 blade vs 12 blade and the 12 blade TD06H isd actually a bigger diameter turbine. Thats why the T67-25G exhaust housing doesnt bolt on to the TD06H-20G
Or soem better photos I have taken
TD06H
L2 Turbine
Side by side
25G Compressor
73HTA Compressor
And this is what happens when you put the TD06H housing on the L2
There has always been confusion surrounding the T67 25G.
Per the kando variant it is a TD06SL2 25G, which I believe is the correct item.
Some people think its a TD06H 25G.
Roy you have a genuine item on shelf, why not just clarify with the calipers?
Yeh wheel spin in 1st when I launched, otherwise I was bogging down.
Let me know when you're thinking of going down again, would be good to compare on the night. Trev, you get up here too! :P
My water meth kit is done, just waiting to change exhaust and cold air intake then retune
Need more overtime shifts to pay for it all :(
Could be turbo design, boost leak, some kind of restriction - is it ball bearing? What was the temperature like on the day by the way? Also, what kind of dyno was it tuned on? One of the reasons I said anything is mine was trapping higher and running quicker times (14.0 @ 110mph even with a TOTAL bogged launch - ~3s 60ft, then missed second gear completely etc when a mate who has a stock turbo R33 had a go) with ~260-270kw @ hubs on 15psi and going by most people here's comments etc that power should be about equivalent to 240kw "Oz dyno" type numbers.
Regardless, I remember when I was running 108-109mph in my car - doesn't make for a slow car by any means, no doubt well worth being happy with but in one way or another it potentially could be a bit quicker with that power.
Turbo is bush bearing I believe. Ambient temperature was 28 degrees, 59% humidity and 7 knot head winds. Dunno how much of a difference that makes. Was tuned on a Dyno Dynamics roller dyno.
The car definitely doesn't feel slow, and over the last half of the track I was catching most of my opponents, I think it was only that silver ute in that vid that started pulling away from me. It's just disappointing that the car always seems to make decent numbers on any dyno it goes on and the tuners don't have anything to say about it, then something happens that undermines that result and tells me it isn't actually making that power. Frustrating with the amount of money that has gone into it, I'd just like to know where to start looking to get it running to it's full potential.
Quick question I might chuck in here.
How do you miss a gear?!
Especially going from 1st to 2nd
How do you go first to 3rd?
Yeh as Lithium said, for me it was slight retardation and too much excitement :P I missed 3rd by trying to change too fast and trying to jam it somewhere between 1st and 3rd. Missed second by hitting the gate and not getting it into gear. Calmed down on my third run and managed to get things smooth, but I like to rev too much :P
Thought some of the guys in here might be interested in this. Video I took earlier today of me in my R34 with ATR43 G3 (350rwhp) vs Jay-rod in his R34 with ATR43 G2.5 (340rwhp):
This is another interesting point. J-Rod made 340rwhp with his G2.5, and I beat him in all the runs we had.
J-Rod. Get your car to Kwinana, I want a comparison! :P
I know the difference in Trust/Greddy speak :) Others are the ones getting confused :) You are right. In Greddy /Trust speak the T67-25G is in Kando speak a TD06SL2 25G
I mentioned TD06H turbine on the bigger FP HTA compressors as they need the bigger turbines for the added torque to spin the compressor . Stao commented.
That is a cropped version of the TD06 turbine, that would shift power band to mid high range. It increases the total dispatching area of a turbine wheel. I used to crop the Sierra S3 turbine wheels ....
I was pointing out we are talking about different things. My TD06H was the bigger diameter turbine with different diam shaft and different number of blades TD06H. I am not sure what back cut wheel he is thinking about .
I have a bigger than 73HTA "Roy Spec" TD06H thing for my stroker to go on in after i cut laps around Albert Park at the Aus GP. :) That will scare 400rwkws on E85 without any lame ass need for lame ass RB25 :) But first lets see tyres blazing from the 73HTA :)
muahaha sounds nice.
i am starting concepts for development of my next stage too, the motor will remain the same but once funds permit and i have had my fun with the HG bolt on i will aim for 500whp myself.
Ok, Lets make a TD06H, probably a good base trailing the billet 90mm 750HP comp wheel that I'm making for the Ford XR6 BA, might need 12 Cm turbine.
I can engineer the comp wheel to suit any sort of shaft, back plate and bearing housing. not a big issue. I will probably do few runs with it after I get proper cams done. By the looks of the TD06H turbine that size should be good for internal gating on a Rb25det also.
Putting the BB SS2 back on dyno next week on high mount setup as well as the SS1PU. Up to this stage the BB SS2 steel felt the best on road in terms of overall drivability. video footage of it with the latest oil delivery setup.
Will post results against the other two once finished.
You can try and blocking up the BOV. that do help with boost lose between gear shift.
i think alternately run that on a external high mount setup and crank 24psi.
The G3 turbocharger was making 370rwkws on a high mount external gate setup which is definitely a big end turbocharger. I have few tricks that I'll be trailing next week and hopefully that helps with turbo's response and down low torque.
There was a covering up sleeve that Garrett made for their Lemans track car's turbocharger back in the days. I can't remember what that turbo was called, it was very similar to a 2860RS with a billet comp wheel.
I had a chat about it with a Garrett engineer which we do some work with, he did mention the purpose of doing was by reducing induction and exducing area of the compressor housing would accelerate the velocity of air dispatched from turbocharger's compressor. There for gain response while trade off top end power. I will do a trail on that with the G3 and see if that gain any noticable differences. will post photos as I go.
Run your ball bearing cores with your new billet TD06s, I'm sure that will turn plenty of eye balls.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to it's full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so damn hot in there, that made it all the more easy to remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. I was standing there looking at the car and said 'f**k it'. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
