I've been running the BB G3 with the latest comp profile for about 1000KMs so far and it appears to hold together well. I can swap this one with any G3 owner for free. PM me if interested.
Dyno results of standard and latest BB unit:
http://www.skylinesaustralia.com/forums/topic/261613-hypergear-hiflow-service-continued/page-352
result only shown difference in 4th gear to floor. the transition and throttle response between the two is quite different.
looking at running water meth injection, whats a safe boost level for the tATR43?
You can run till it stops making power. Around 24psi
Hey Stao do you mean even my thrust bearing g3 can be updated to BB aswell as the updated comp housing?
Yes I can rebuild your bush bearing G3 into ball bearing and updated comp housing. in this case I will swap you with the one that is currently in my car free. I will need your turbocharger back for a day or two for a small modification on the turbine housing as well as the comp housing.
The ball bearing update can apply to all Gx, Gx based Rb highflows, SS2, and SS3 turbochargers.
Hi all,
Went out to WSID last night to run the car for first time since my PU highflow.
First run was a 13.2 @ 115mph with a rubbish 2.2 60ft
Second run does not bear a mention and then it PISSED DOWN RAIN
I was really hoping to bust into the 12's but im not sure it (or the useless driver!) will manage it.
Anyway, just thought id share that with the internets
It dyno'd at 280ish rwkw but it does feel a little down on hp. That being said i did have some problems with traction off the line.
What sort of trap speed should i be expecting assuming the 280kw?
Well to get fast time you will need small rims with fat simeslick tyres (hint from Trent), I used to skit all over 3rd gear with a G3 on my road tyres and that was a slow 330rwkws. Run RSRs or better will help heaps.
After doing abit of reading on the net, its not a bad time for a stock weighted R33 internally gated, stock manifold on pump 98 at that power level, there is a huge difference in mid to top end range torque with high mount and external gate after 120km/h. But I don't know how the car run slower and slower after each pull.
Also G3 is changing, I will post some photos of the latest G3 tomorrow, in hopping for the same power level with much better throttle response, it will also be equipped with the latest bearing and lubrication setup as well as optional ball bearing.
Hi all,
Nice, sounds on the money to me. I did 13.3 @ 112mph off a 2.2s 60ft with a bit less power on street tyres on an airstrip with my GT3076R. Put stickier tyres on it and ran 12.6 @ 112mph off a 1.9s 60ft (same strip, same driver... I was still learning how to make it work, not great traction) - it took me low 2.0s 60fts to get into the 12s from memory so not far away.
I reckon the delivery of the turbo plays a definite part in the ET, and the on-off responsiveness between gears in the trap speed and ET for sure. The G3 as Stao says has good 'rush' up top, but a little lazy in and out of gears (on stock manifold low mount I mean) and kind of like a light switch delivery in 1st and 2nd which makes juggling bog/wheelspin hard off the line.
And obviously driver experience at the strip :P
Yeh I think Luke's and my trap results are very effected by boost response between gears. Took the car for a drive the other night and tested that out, and I've got about half a second to a full second of lag between each gear change.
You will find the BB G3 with the latest comp profile changes that power delivery behavior by a lot. It smooths the power delivery pattern, which takes out that big launch behavior, sticks the car on the road better.
That lag you explained would absolutely kill mph, if its that bad...glad im auto..lol,
looking at the G3 drag vids, they do look lazy
cheers
darren
Edited by jet_r31
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
