Gee by the time I get my car 100% there's gonna be 100 new better turbos available.
Keep up the good work Stao!
If its off the car you can send it back to me for a update. The main difference in the SS2 would be the Type B rear housing and compressor housing.
Just came back from Drags :)
Very very happy
I can confirm its driver error that's causing my low times.
I think i could get a low 13s ( or a better driver )
Got a 13.822 @ 171.3km/h
Around a 4k launch
FYI
ATR45G2.5 is my turbo @ ~340hp
Very very happy
Around a 4k launch
FYI
Low 13's is definately possible, however 106mph means you aren't anywhere near 340rwhp.......
What have you changed in this new ss2.5? Is it a turbine change?
PM me if you would prefer
That BB SS2.5 has a larger turbine, that is only good for high flowing use. getting it back on the dyno Monday. The prototype SS2 had a different set of blades, making minor changes to boost ramp behavior.
I ran that exact time and speed with an S14 making 175rwkw with stock turbo.
my 60' was 1.8.
Unless your 60' was like 2.2 or higher and you missed gears a couple of times, it will be more than driver error that's the issue.
my 60' was 1.8.
Wow that's a huge difference in power
How much experience did you have prior to this run?
I don't know about 115mph, but 106mph is way low for ~250wkw. Quite an odd pattern forming!
Not wrong there, all the drags results are showing that you would be better off with a stock turbo.
First and only time at drags.
Got 4 runs.
first one was a 14.4 then eventually got 13.8 on the 4th run.
I kept shifting at 7K (silly in an SR) and would just touch the rev limiter in 3rd as I crossed the line.
Could have possibly been quicker if I shifted earlier but never got to go back.
Car was a series 1 S14 with heavy 17s.
255s on the back with pressure reduced to about 22psi
Stock Clutch, FMIC, 1 bar boost, pod, exhaust and tuned SAFC II
Done by Yavus at Unigroup
175.4rwkw
Stock turbo and clutch do make it easier to launch more consistantly though.
And the SR20 is a different torque curve to the RB so possibly easier to control wheel spin.
Edit - I should take my current car (stock RB25 R32 gtst) to get some base times.
Edited by TTT
Seems to be pretty normal
I did 13.32 with 112Mph that was stock weighted R34 with a pu high flow 280rwkws on street tyres. Stock turbo run 14.6 with 98mph on 12psi with 200rwkws
Edited by GeorgesR34
Just to show you how off your figures are. My non turbo 300ZX trapped 97.6mph with ~130rwkw, yet your R34 had "200rwkw" ;) Trap speed tells no lies
Can a turbo perform better on a dyno than on the road?
Like could two turbos that makes 250rwkw with the similar power curve get totally different results on the road.
Very easily, what i don't understand is how these turbos keep underperforming on the drag strip.
Edited by Super Drager
Punching your 97.6mph trap speed into a drag strip calculator - to only have ~130rwkw you would need to be weighing around 1315kg - the 300zx non-turbo (from my googling around) is around 1460kg without a driver. That's not an insignificant weight difference. Not questioning you - just curious :)
Was going to say that - my Prelude needed around 130kw to pull 96-98mph trap speeds and weighed ~1330kg as raced, must be an ultra low reading dyno to do 97+ with a "130kw" 300ZX.
I'd hope for over 98mph with 200kw in an R33 too, though.
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
