$800 including oil line. Depending on when can get it tuned, will be looking towards a weekish mark.
Also this high flow is made to aim 400rwkws mark, So it might not be very responsive.
Stao. Would you have a run of the new high flow against the ss1pu turbo i've got? Appears all the SS turbos runs the same compressor wheel, please share some light of the difference between the three.
SS1PU runs a turbine sized similarly to a GT28, GT28 spec rear housing and T04B front
SS2 runs a turbine sized similarly to a GT30, 5 bolt T3 rear and T04S front
SS2.5 Highflow runs a completely custom spec turbine (will leave details to Stao), stock 2IU housings
Some further updates. Since the majority of market is pushing for a cheap and cheaper option, I've managed to find and import some 21U copied turbine housings from China. Crazily machinery costs is only 1/30th of what my accumulation is in Australia.
So here it is, a Cheap turbocharger that produces decent power and response. The ATR43G3.5. Since 1/3 of the turbo and machinery work is done overseas. I can manage to squeeze the price down to only $850 including braided oil feeding line.
Dyno trailed today with very successful outcomes. It managed to archive 355rwkws, maxing out at 22psi. Far as pricing concern, this makes the lowest $/KW ratio turbocharger with added benefit of Rb2x bolton.
It is pretty aggressive on road. expecting to see some where around the 320rwkws used as a internally gated turbo on pump 98. I've already mentioned the limit of stock exhaust manifold, so its up to the end user to sort out their own manifold and other supporting mods.
Stao, all you need to do now is take that turbo to the drags.
Get us a trap speed to verify the power and watch them fly out the door.
If the trap speed is indicative of the power I think you will be selling these faster than you can produce them.
Its using a 2IU exhaust housing rather than a .82 type A/B
The turbine wheel has been re-done to better match the tight 2IU housing.
It seems to have been developed to be 100% bolt-on ready and can be further developed down the track to have monster high mount potential.
The G3 and SS2 do produce noticeably strong mid to top range power with better transition response since they are built with a small turbine and the advantage of a reasonably large housing.
This turbocharger is good for a budget built. Like all other ATR, with very high external gate high mount potentials.
I will be working on the SL2 10cm based turbochargers next week. releasing 2 new models.
Hey all, after having a chat to Stao today I am tossing up between the SS2 or the new 3.5G
Has anyone got a dyno graph of SS2 on 98 internally gated on standard manifold?
Thanks
The SS2 for RB25det is only in T3 .82 FNT rear with RB's IWG assembly. The latest one is slightly more responsive:
http://www.skylinesaustralia.com/forums/topic/261613-hypergear-hiflow-service-continued/page-360
and required lot less duty on the ebc. So it will work better with factory manifold internally gated.
This is video track footage from John. Running a standard high flow from 2 years ago. It should be the last run of it as its getting a update to the latest SS2.5 profile.
car is currently on 260rwkws.
had a retune @ garage 101 the other day
as it stands it has
3" TBE
ATR43 with .63 trim - 4" inlet pipe and pod
hybrid inlet manifold and low mount exhaust manifold
850cc injectors
walbro
new clutch
think thats it
366whp @ 17psi
FYI
I am going to racewars (perth) and will be racing.
I guess ill be the first Hypergear Turbo to do a 1000 meter sprint?
Will be happening this weekend, hope to get as close to 300 as possible :):)
Will post my results up when im done :P
FYI
My guess is about 240-250kph.
    • I am well aware as I did rant at him to buy a MX5, buy the 2.5 before he DIY'ed it, etc as well as do things to the holden. He will obtain a ND. It's the best of both worlds. They look great in person, definitely the best looking one. Just a matter of time now.
    • Remember this is the same person who said he’d never own an nc
    • ouch! how is the car now?I had sold my gtr but have been looking into some on trademe and a 260RS but I wouldnt be keen on any repairs needed on them
    • This sounds like someone who would have owned an R33 in their past... It's okay, I'm 100% picking up what you're putting down Mark.
    • Just back on what was raised about jacking off the the tow/tie down point on the front of cars. I've used it plenty. I've also watched it on a car where you could see it move the front end of the car. It was like the front end/whole car being tweaked and twisted a bit. I will say, I struggle to find good jacking points on MOST cars. The ones that have good points, I then normally struggle to find a jack tall enough to make the car change height!   One of my go to points for either the jack, or the axel stands though, is either a suspension pickup point, OR a subframe to chassis major bolting point. I actually think its the subframe on my R33 that has a bit of a bend in it, from being jacked in the middle too. However, it could have been one of my many other cars I've had over the years! Or it could also be the from me jacking it up, and the fact the top of the front radiator support isn't there, so it can allow the front of the car to move and bend etc.
