Also better pics of the dyno graph:
Green is my old setup: stock engine + china manifold
Blue: Is the forged ported engine + Brae manifold
Everything else is the same
Its a normal intercooler just the attached piping is return flow
Sort like this pic I found on google
So if Scotty where to fix up some of the bends it might be better lol?
As im going to assume its the angle of the bends not the length of the pipe that might be the restriction?
Is hybrid intercoolers any good? Dont know much about them
Personally I highly doubt it has anything to do with the bend causing restriction. Mine was a pretty fkn brutal bend as well as being 2.5" piping and didn't have any issues flowing 295rwkw.
Interesting!
Though 284rwkw and 295rwkw isn't much difference lol
Have there actually been results with these turbos on an RB25 making more power on straight pump gas? I've made noises about the wondering how the VNT/FNT technology would perform on pump gas when being leaned on - partly because I am curious about how exhaust manifold pressure is going to behave with what could be defined as obstructions along the flow path towards the turbine. E85 can mask some effects of soaring pressure (ie, being much more knock resistant) but with pump gas it is going to start complaining quite quickly if it is a bit excessive.
The principle behind VNT could easily be thought of as being equivalent to being variable A/R in regards to it's effect, and relies heavily on correct actuation to not become a restriction at the wrong point and also providing good spool - however how FNT has had me fascinated is that surely there is the potential that it has the net effect of providing a larger a/r that flows (and spools) like a smaller one, to some degree defeating the purpose?
I have been specifically waiting for pump gas results to see how these go and this is the first FNT I have noticed being leaned on using pump gas and the result is what I would have expected with "nozzles" angled to boost spool which don't adjust once flow requirements increase. There may be results for this setup which prove that it is fine, so I am absolutely by no means suggesting that I believe there would be an issue with it - I am just voicing an idea which hopefully can easily be proven wrong to eliminate, or otherwise provide a possible explanation.
Interesting!
That's true, though it was at ~17psi and the tuner said it still had more but he stopped there because it's a standard engine (read: he's a big softy sooky-lala)
Stao was originally doing all his testing on pump 98 man. All the FNT gear was originally produced with pump 98, and he didn't have an issue. There are a tonne of 98 based FNT results (from Stao's test car, same tuner same dyno) in the dyno thread.
See below hekkas MS Paint representation of what my bend looked like. Yes, the piping didn't even make 90 degrees before meeting the next part of the bend.
Thought that could be the case - any examples out of curiosity? I did a search for "FNT" and the only result that came up for me was Hanaldo's which I have the impression the entire setup has never quite delivered for him, yet?
One thing I forgot to mention
With the new engine, Trent had to take out 8 degrees of timing compared to the old engine, as any more it would be pinging too much.
Fuel used was BP 98. Filled up only a couple days before hand
Almost all results pre page 43 on the dyno thread is on 98 ron, bar like 2 posts max.. Once Stao went to E85 he never wen't back.
To my understanding the turbine side of things reached a point where no changes were needed beyond housings and compressors. Thus he did a back to back with the SS2 when he went to E85 and any advancement from there can be seen as an improvement regardless of what fuel you are running.
Here is page 43 where he first changed to the current full blade SS2 on 98, that is an FNT IWG item and went 312kw:
http://www.skylinesaustralia.com/forums/topic/55845-rb25-turbo-upgrade-all-dyno-results/page-43
I am fairly sure the 312kw item is the new version.
Old version is the high/low blade 71mm compressor, like what can be found in my SS1PU. Fairly high tip height with familiar looking blade curvature.
New version Stao played with the 'full blade' design and found it to work quite well. Full blade SS2 is 74mm.
So in theory the new one may be higher flowing? Here's Stao's post that made me think the 312kw was an old version http://www.skylinesaustralia.com/forums/index.php?/topic/261613-Hypergear-Hiflow-Service-Continued.#entry6948624
In the 312 result he noted it as being a prototype, which I am sure was the move to the full blade wheel. However, the older SS2 was also 300kw capable.
Time for Stao to chime in and clarify now lol
This is the result from the latest SS2 FNT model on pump 98, stock manifolds, internally gated as previous posted. The older version is no longer manufactured.
I had a quick chat with Trent (tuner) about With Blah_blah's result. Apparently he pulled 8 degrees of timing out of his old map, as it some how knocked badly. Meanwhile the stock engine did not have this issue using the same turbocharger and the rest of the setup.
Reasons given by his engine builder was that because the head ports are now over sized so they flow much more then what they were standard. And the extra flow now demands for a larger rear housing. I personally do not have any experience with ported heads so I can't comment.
Well, bigger rear end is not a problem, I have them in 1.02 rear or .82 turbine housing with a bigger G4 turbine wheel.
Hmm interesting - if it were enough porting to cause that effect then that potentially means too much porting, I'd have thought! Its not miles behind in power for 8deg less timing though, at least?
It may not even be the rear housing it may be the turbo altogether is a bad match now...I mean you design your turbos to match a rb25s power zone...that is 3500-6500....he has now designed a head that is probably more suited to flow from 4000-8000 so a bigger turbo all together may be what's in order..
Will the ss2 even spin to 8k or will it drop off power too early?
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
