For power and response on RB20det SS1 or SS1.5 .64 is perfect and made for that engine. Those two are highly recommended over high flowing. Alternatively yes we can also high flow the stock turbocharger to be responsive which will be maxing around 200rwkws mark.
Around 200rwk is fine Stao, response is more important to me. What would be more responsive the rb20 highflow or SS1 or SS1.5, or a highflow with one of the SS billet comp wheels?
Result sent in from another customer. This time it is a ATR43SLSS2 turbocharger in a 8cm turbine. It is fitted on to a FJ20det engine in a Datsan 1600. With supporting mods final result of 257rwkws on pump 98 fuel.
Im not really sure mate didn't get much info bar the wastegate having no boost control. I will mension this to him tomorrow and see what he has to say and report back :)
Annoying only finding it once it went onto the dyno >_<
With the bolt on SS2, Just had a quick chat with Trent today. The boost became controllable after the long stud securing the dump pipe was replaced with a shorter one. The car is currently sitting at 20psi and making 301rwkws on pump 98 fuel.
He also said the gate is only restricted to a 40 degrees swing which they were engineered and checked to 70 degrees. I'm not sure if the long stud has forced its way into and bent the wastegate assembly that made the disc catching on to the rear casting, which I understand it would be torqued up tightly. Trent is trying to lower 3psi and fill in a little bit of extra timing. I will be heading down there to inspect the turbocharger on Thursday and it will be checked out and repaired by then.
Some updates from SS-4 Alpha ptotoype 1.
This turbocharger made 465rwkws on 24psi maxing out the 850cc injectors that is installed without gain additional lag. With a set of 1200ccs on 29psi it should be getting very close to 500rwkws mark. Big thanks to chequered tuning again.
Thick yellow is from today, the rest is the controlled run.
Holy shit.
I'm no expert but for 450 at the wheels (with 500 potentially possible) that thing looks mighty responsive. Of course it's tardy, but to be ramping hard from under 4k suggests it's not the undriveable lag monster one might assume. Did you drive it on the road, Stao?
Got any pics of it installed?
Not just the KW'S take a look at the FARKING TORQUE. Its incredible. And to have it coming on so early is a good result. What ar. Rear housing on this Stao? (Sorry if already stated).
Those new tomei camshafts seem to be doing there job also. Is there any lumpyiness to the idle with 264's in&out 8.9 lift or is it still quite smooth? TOP WORK STAO. YOU DESERVE A PWT ON THE BACK FOR ALLVYOUR EFFORT MATEY :)
JOSH
Its definitely not laggy for the power but you think a 200+kw surge of power from 4K-5K would be "driveable?" Lol! I know the dyno only tells half the story as cars still drive different on the road than when they are being loaded up on a dyno, but I think after that initial 200kw WHACK the power looks quite linear and then the "driveability" begins. Awesome result Stao :) very impressive power & response indeed!
Wish you could add some BB billet goodness to an evo 9 turbo for me cos id be all over it! :(
Edited by Mick_o
Hey have a look at the kando evo 9 turbo with billet comp wheel
My brother has bought one to try on his evo 8 and step one cams
That is as awesome result
Is that still the same cast one you trialed before ?
It's ceramic bearing and vnt but std cast compressor
Thanks for the tip mate but im kinda after a more "special" Ive thrown nothing but the best gear in the evo and its paid off with my results so far :) what kinda power did ya bro's 8 make with the kando?
Certainly a mixed of pessimistic and positive comments.
Well this is the first SS4CBB Alpha prototype evaluation, so nothing is set to be final at this stage.
This thread is dedicated to turbocharger innovations for Nissan 2.5L Rb25det engines. Which power delivery behavior or results in similar HP range gathered from other engines are not helpful.
Taking account of your comment Micky_o. With the Mickey T tires it is quite driveable, in which it did has a smooth start following a very aggressive pull. It is different to the ATR45 trail in Feb, which had a much heavier exhaust note, with a sudden pull behavior.
A set of 1200cc injectors are coming for the next tune, I will add some alterations to the current turbine system. The goal would be shifting the same amount of power 300RPM left of the scale.
Nice result, looks like a bit of a beast so far - be interesting to see how it goes with the bigger injectors!
What kind of price would this kind of thing be going for?
Yeah the results look fantastic hey LITHIUM, ESPECIALLY once the new injectors go in and he pushes that extra 5psi+ into it. :) I asked Stao a price and he said the 2.5g mark.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
    • I was able to get some underside photos while the car was on the ramp The suspension is all Altezza/IS200/IS300 so getting part's will hopefully be less of a headache
