What's the deal with people taking blurry cropped photos!?!
Was there only one shot left on the film?
The conspiracy theorist in me says that if the photo was clear it would show 12.8 !
Either way 120mph is a great result especially for that turbo.
Not sure what it might be in this case. Same customer posted up a bluer photo of his quarter result on facebook. I will update an more accurate result once I get a responds.
The new wheel combination seems to be working nicely inside 1JZGTE VVTi CT15B housings as well.
Latest result:
Toyota Soarer
1JZGTE VVTi Manual
Car has 650 cc injectors
PFC ECU
Front mount cooler
3 inches turbo back exhaust
Aftermarket exhaust manifold
3 inches metal induction pipe with pod filter.
Most power made was 312rwkws @ 23psi, Left on 293rwkws @ 20psi. Car makes 200rwkws by 4000RPMs with excellent on road driving ability.
Got my new apexi intake today measured 3.5inches
That and a new walbro 450lph pump to replace my old dw300 will hopefully see my ss1.5 sr20 at 280kw
As we tested fuel pressure and it was dropping 6-10 psi up top on the dyno as I'm running a extra bar of fuel pressure over std and my fuel pump can't keep up
Afr were going from 12 to 12.5 as fuel pressure dropped so may gain 5-10kw if we can keep afr constant and Tao tested the 2.5inch intake vs 3inch was 13kw
Will get it retuned in a few months after I buy a new fuel pump
I'm on nismo 740cc side feed injectors and trying to squeeze the most out of then as I'm on e85
43psi base + 14.7psi ontop of base and 25psi boost that's 83psi fuel pressure so flow from the dw300 will drop drastically
Yeah is still slighty down on power to Tao but new intake and pump should put it closer to Tao results
Also most dynos vary abit but a true indication of the power will be down the quarter mile which I'll be testing soon
So far at 250kw trapped 120mph
260kw trapped 122mph
I'm going to test it as is now and after I put on the new intake and pump
Some results sent in from B-Rice:
This is standard 21U high flow on E85 managing 292rwkws on E85 fuel and factory actuator:
Clutch is slipping little up top, and I believe an high pressure actuator should be able to hold boost straight with a gain of another 30kws.
A result sent in from an SS1PU customer. This is the latest version also that has a different compressor that is engineered to hold boost better and more top end.
It is running on E85 maxing out fuel pump. Peek of 301rwkws @ 17psi. With plenty of mid range.
From customer's feed back letter:
R34 GTT (Stock Motor)
Supporting Mods
Blitz FMIC Return Flow
1000cc Injectors
Standard Airbox (Panel Filter)
3inch Bellmouth Full Exhaust
Z32 AFM
Walbro 255 Fuel Pump
SS1PU (latest model)
Scotty's Alloy Intake
CALTEX E-Flex
301.8 Rwkw (18psi peak, drops off to 17psi holds well)
I did a rough overlay of these results with B-rice's
It looks to me like the highflow r34 turbo is one of the top performers in the 300rwkw E85 range
Unless im a total twat and have farked this up haha
Actually, I think it was a R33 21U high flowed turbo. The updated high flow probably works out to be similar to a SS1PU.
There are two profiles for the OP6, we can still use the old configuration which keeps it responsive and maxing out towards 260rwkws while the later configurations would be maxing towards 300rwkws with more lag.
I'm working on a new version of high flow for Rb20det motors. The expected out come will be very similar to a 2530. Will update photos as its been completed.
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
