Do you ever pass 98RON through the tank? it's good to run 98RON every 10 tanks of E85 or so.
No-one told me this, and now I have gone and ruined my car... 5 years straight now. :/
and how do you go about doing that on an e85 tune?!!?!
I'm basing this on the assumption he has 2x tunes (which he might not).
Says who?
Five O Motorsports themselves and various other US based forums.
LOL... man you guys are digressing! I was saying to pass 98RON through the car every so often to keep the injectors happy.
Remember that these crappy highflow injectors are modified old tech sidefeeds that were designed in an era where high alcohol content fuels were nothing but a dream.
  • Like 1
lol.... yes I am aware of that, but for some we just don't pour all our money into our cars and do what we can
But what has it cost you? In wasted time and hassle?
yeah and loads of swearing - if I "had" a NEO motor I would have just drop in modern top feeds and would have called it a day.
Dude I've got the same injectors as you haha
I heard good things from 2 people and thought they'd be sweet..... nahh
Yeah I wish I had one too. I swapped out a dead R33 motor for another 33 25 that I have now.
Didn't realise the huge benefits of running the R34 motor at the time, should have done that instead
higher lift stock cams, drop in top feeds, beefier factory bottom end.. drool
Edited by Blackkers
Drops a 34 Neo in because changing the fuel rail is just all too hard. :P
Yeah just read up on that if running e85 constantly injector tips tend to gum up and even gm commodore flex cars in the states got told to run a tank of pump 98 clears up the gum
I'm on single nistune map so e85 constantly but am going to just run a e85 fuels system cleaner now on with every oil change
Edited by hy_rpm
Yeah just read up on that if running e85 constantly injector tips tend to gum up and even commodore flex cars in the states got told to run a tank of pump 98 clears up the gum
If you change fuel filters often enough shouldn't have any problems, 3 years so far for me full time e85 and everything is clean fuel filters, injectors.
I agree, mine has never been apart since I shoved the 1000's in there 5 years ago. I would imagine the tips may have some black gunk around them, but it hasn't blocked the internal injector filter, and the 40 micron stainless filters obviously let it through without gumming up. I do run teflon fuel lines though, and I am a little worried the black gunk is from the stock rubber lines.
There are two choices, change your paper filter more often, or change to a slightly more coarse stainless 30-40 micron and hopefully forget about it.
Another thing, don't use the little filter in the top that fits into the adapters, unless you want to replace them regularly. They clog up with that black gunk quickly as the surface area is minimal. I have seen it a few times now.
forums.nasioc.com/forums/showthread.php?p=37242444
Post 42
Thanks for the tip. That is pretty crazy, I thought E85 should be cleaning the injectors since it made every thing else internally pretty clean. my daily driver KIA is on E85 all times and done 23,000KMs with it so far. I will pull it out for a check up this weekend.
Yeah worth the check but even injector cleaner isn't the best solution
Running a tank of normal unleaded dissolves this gunk and mainly affects city driven cars stop and go
But if you mainly do highway kms not as bad
Might just add 10-15l pump 98 to a tank of e85 at each oil change might run very rich but dissolve this goo
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
    • wedding eh.....I seem to get to more funerals than weddings or christenings these days....
