hypergear Posted July 17, 2014 Author Share Posted July 17, 2014 Power Enterprise 800cc injectors. I've used two sets in two of my cars, they worked great, better fuel economy too. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/505/#findComment-7342056 Share on other sites More sharing options...
Dose Pipe Sutututu Posted July 17, 2014 Share Posted July 17, 2014 I'm planning to move to these injectors: http://www.injectorshop.com.au/product/siemens-ev14-875cc-12-ohm/ I've contacted the shop - however still waiting on a response. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/505/#findComment-7342179 Share on other sites More sharing options...
scotty nm35 Posted July 17, 2014 Share Posted July 17, 2014 I hope those Siemen's are better than the ones I used to run... I would hate for you to have issues with another set of injectors to save $10ea Johnny. I just picked up a set of stainless 1400's for my evo 7 today, we are tuning the reverse rotation SS2 Hypergear evo highflow on the weekend, stock exhaust, intake and cooler for the engine run in. Should be interesting. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/505/#findComment-7342303 Share on other sites More sharing options...
iruvyouskyrine Posted July 17, 2014 Share Posted July 17, 2014 If you are using this fuel pump: You must run two earth. You can just Tee it from the factory wiring and connect it straight to - terminal of your battery. It will then work. Interesting that you should say that. I have mine required through a 60 Amp relay and suitable wiring, and twice it has killed the earth. Both times the car was running perfect, left it for an hour or two and it just wouldn't prime. Both times the earth went open circuit. All other wires were fine but the earth was dead, and there didn't appear to be any damage to the wire. Certainly didn't look like it had had too much current through it. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/505/#findComment-7342304 Share on other sites More sharing options...
scotty nm35 Posted July 17, 2014 Share Posted July 17, 2014 Interesting that you should say that. I have mine required through a 60 Amp relay and suitable wiring, and twice it has killed the earth. Both times the car was running perfect, left it for an hour or two and it just wouldn't prime. Both times the earth went open circuit. All other wires were fine but the earth was dead, and there didn't appear to be any damage to the wire. Certainly didn't look like it had had too much current through it. Why wouldn't you run a dedicated earth back to the battery though, while you run the positive? Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/505/#findComment-7342307 Share on other sites More sharing options...
iruvyouskyrine Posted July 17, 2014 Share Posted July 17, 2014 If you are using this fuel pump: You must run two earth. You can just Tee it from the factory wiring and connect it straight to - terminal of your battery. It will then work. Interesting that you should say that. I have mine required through a 60 Amp relay and suitable wiring, and twice it has killed the earth. Both times the car was running perfect, left it for an hour or two and it just wouldn't prime. Both times the earth went open circuit. All other wires were fine but the earth was dead, and there didn't appear to be any damage to the wire. Certainly didn't look like it had had too much current through it. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/505/#findComment-7342309 Share on other sites More sharing options...
hy_rpm Posted July 17, 2014 Share Posted July 17, 2014 I hope those Siemen's are better than the ones I used to run... I would hate for you to have issues with another set of injectors to save $10ea Johnny. I just picked up a set of stainless 1400's for my evo 7 today, we are tuning the reverse rotation SS2 Hypergear evo highflow on the weekend, stock exhaust, intake and cooler for the engine run in. Should be interesting. Would be intresting to see your results on the evo 7 Mine made 285awkw on 25psi Turbo is back at stao now for a turbine wheel upgrade to a td06h4 Hoping to gain better response and crack 300kw Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/505/#findComment-7342330 Share on other sites More sharing options...
scotty nm35 Posted July 17, 2014 Share Posted July 17, 2014 The stock exhaust will be pushed hard, 2.3 Manley stroker, HKS step 2 cams with adj wheels, the rest is as factory. It's the most un-defectable car it will ever be, for a few weeks at least. If I can squeeze 250kw out of it I will be impressed. That will do me while the engine is run in. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/505/#findComment-7342336 Share on other sites More sharing options...
Manuel Kasko Posted July 17, 2014 Share Posted July 17, 2014 Keen to see how those injectors go Scotty because those are the ones I'll be picking up off you when I get back. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/505/#findComment-7342342 Share on other sites More sharing options...
scotty nm35 Posted July 17, 2014 Share Posted July 17, 2014 Keen to see how those injectors go Scotty because those are the ones I'll be picking up off you when I get back. I have installed them on quite a few cars lately, they idle fine as you would expect from a modern injector, no issues at all with them. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/505/#findComment-7342487 Share on other sites More sharing options...
GTScotT Posted July 17, 2014 Share Posted July 17, 2014 Looks like Im the only one left with five0 injectors that havent died yet lol I ordered 1 Spare now incase they do ever die while im at the track. So even on e85 you still having idle problems? Thats strange Nah, mine are still doing 295kw and 10L/100km. HIGH FFIIIIIIVVEE!! Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/505/#findComment-7342562 Share on other sites More sharing options...
Dose Pipe Sutututu Posted July 17, 2014 Share Posted July 17, 2014 T Nah, mine are still doing 295kw and 10L/100km. HIGH FFIIIIIIVVEE!! They perform differently on a SR - I fitted and tuned a set of 1000cc and my mate is getting 400km per tank on E85. Only about 120km less per tank than 98RON Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/505/#findComment-7342563 Share on other sites More sharing options...
GTScotT Posted July 17, 2014 Share Posted July 17, 2014 Economy perhaps but there seems to be an issue with more recent batches with longevity. Really odd.. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/505/#findComment-7342570 Share on other sites More sharing options...
boostn0199 Posted July 17, 2014 Share Posted July 17, 2014 T They perform differently on a SR - I fitted and tuned a set of 1000cc and my mate is getting 400km per tank on E85. Only about 120km less per tank than 98RON Mines on are RB, most the failures and issues have been with people using the 1200's maybe there the issue cause im using 1000s. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/505/#findComment-7342579 Share on other sites More sharing options...
GTScotT Posted July 17, 2014 Share Posted July 17, 2014 And me 850s. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/505/#findComment-7342581 Share on other sites More sharing options...
Dose Pipe Sutututu Posted July 17, 2014 Share Posted July 17, 2014 They probably used a bigger drill bit and it's causing all the issues. Also the spray pattern looks like ass, I'm pretty sad I jumped the gun and bought these water pistols. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/505/#findComment-7342585 Share on other sites More sharing options...
Manuel Kasko Posted July 17, 2014 Share Posted July 17, 2014 They probably used a bigger drill bit and it's causing all the issues. Also the spray pattern looks like ass, I'm pretty sad I jumped the gun and bought these water pistols. When you make a mistake there is only three things you should ever do about it Admit it Learn from it Don't repeat it Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/505/#findComment-7342597 Share on other sites More sharing options...
Dose Pipe Sutututu Posted July 17, 2014 Share Posted July 17, 2014 When you make a mistake there is only three things you should ever do about it Admit it Learn from it Don't repeat it Expensive lesson I have admit they suck and taken my learnings and documented it on nissansilvia.com Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/505/#findComment-7342638 Share on other sites More sharing options...
scotty nm35 Posted July 17, 2014 Share Posted July 17, 2014 Perhaps they are damaging the coil with the drill bit? Seems very unusual they go open circuit... Just keep a few spares in the glovebox. lol Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/505/#findComment-7342681 Share on other sites More sharing options...
Dose Pipe Sutututu Posted July 17, 2014 Share Posted July 17, 2014 Perhaps they are damaging the coil with the drill bit? Seems very unusual they go open circuit... Just keep a few spares in the glovebox. lol Probably their drill press operator went a little too deep LOL Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/505/#findComment-7342730 Share on other sites More sharing options...
