Hi Guys,
Is it better to run vacuum off the compressor housing to the boost controller or block that off and run it from the stock location in R33s (intercooler pipe?)
My ATR45SAT has it on the compressor housing and a friend with a similar turbo just blocked off his compressor housing one and ran as per above.
Thanks!
Thanks Dan, I read something similar just wanted to double check.
Another question - Does anyone know what size the studs are on the Hypergear ATR45 turbo dump side - I understand that most are actually bolts but there are two studs also.
I'm interested in how much to upgrade SS2 will cost, The new one sounds unreal and mine is due for a retune with E85 and new injectors when I can get all the parts together and on the car so the thought of upgrading turbo sounds good to me :)
the power bug, clearly we both have more than enough power but noooooo let's make more LOL
Haha.
Honestly, mine is probably about perfect for driving around town, which is pretty much all it does.
But now that we have E85 on pump, i know im going to make more power so may as well make a bit more on top of that :)
Haha.
I just want a little less lag as I track the car quite a bit at Wakefield (which is what I mainly use it for, does see the odd trip to the gym).
I find with the SS2 I need to drop it down to 2nd around certain bends, then bam I have too much torque/power and it's dori & smoke LOL.
However it's tits on the straight at Wakefield, I over take cars like no tomorrow haha.. here's a good clip of just that:
Hey Stao, when you get back just so you don't miss my question but will the SS1PU be more snappy and responsive than the SS2?
Plus more responsive than say the OP6?
yes that should be, and more responsive then a op6 high flow. but will be maxing towards 270rwkws mark.
looked like that 34 was slowing for the pits... lol :nyaanyaa:
my SS2 is lags, it's nothing nothing nothing then ALL IN like a rocket ship LOL
these days I drop it back into 2nd on that last turn to keep the revs above 4k
  • Like 4
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
