Hi Guys,
Is it better to run vacuum off the compressor housing to the boost controller or block that off and run it from the stock location in R33s (intercooler pipe?)
My ATR45SAT has it on the compressor housing and a friend with a similar turbo just blocked off his compressor housing one and ran as per above.
Thanks!
Thanks Dan, I read something similar just wanted to double check.
Another question - Does anyone know what size the studs are on the Hypergear ATR45 turbo dump side - I understand that most are actually bolts but there are two studs also.
I'm interested in how much to upgrade SS2 will cost, The new one sounds unreal and mine is due for a retune with E85 and new injectors when I can get all the parts together and on the car so the thought of upgrading turbo sounds good to me :)
the power bug, clearly we both have more than enough power but noooooo let's make more LOL
Haha.
Honestly, mine is probably about perfect for driving around town, which is pretty much all it does.
But now that we have E85 on pump, i know im going to make more power so may as well make a bit more on top of that :)
Haha.
I just want a little less lag as I track the car quite a bit at Wakefield (which is what I mainly use it for, does see the odd trip to the gym).
I find with the SS2 I need to drop it down to 2nd around certain bends, then bam I have too much torque/power and it's dori & smoke LOL.
However it's tits on the straight at Wakefield, I over take cars like no tomorrow haha.. here's a good clip of just that:
Hey Stao, when you get back just so you don't miss my question but will the SS1PU be more snappy and responsive than the SS2?
Plus more responsive than say the OP6?
yes that should be, and more responsive then a op6 high flow. but will be maxing towards 270rwkws mark.
looked like that 34 was slowing for the pits... lol :nyaanyaa:
my SS2 is lags, it's nothing nothing nothing then ALL IN like a rocket ship LOL
these days I drop it back into 2nd on that last turn to keep the revs above 4k
  • Like 4
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
    • 8.5 +37 = should fit rear, but I think it'll hit on front. What you want is low 30s/high 20's front, mid 30's rear. That 17" screenshot you posted looks good, I'd run it on my R32 (but that's long dead now). For tyre sizes, my rule of thumb is: 8': 235, 9": 255. But that's just my opinion. Nismo sizes: 18x8.5+35/18x9.5+38 is a good starting point.
