Most i seen was 266kw from my car 25psi dropping e85 and that was with the larger rear housing .86
Stock bottom end sr but
I would reccomend going the atr28ss2 in bb with .64 rear housing more responsive due to the smaller rear and i made 280kw with this
On a built motor with larger cams and custom exhaust manifold i would see it making 300kw
Action Dan: Yes. the factory exhaust manifold is a restriction and SR needs cams to make power. Plus your usual free flow FMIC, induction and exhaust.
Ask tao im sure he can arrange that
Most results ar from rbs but usually all in by 4000rpm and there only running t3 single scroll
Twinscroll will help alot hence why evos get away with 300kw turbos but are still responsive
This particular SR20det engine is something built by forcedmotor works 4 years ago. It run one of our ATR45SAT turbo compete and won WTAC Open class in 2016 and is still a current world record holder of the fastest SR on Wakefield. Its on a single T3 scroll manifold running external gate, and that pumped 400rwkws on E85 fuel, 28psi by 4250RPM. Far as I know its just a standard rebuild, no VCT with forged pistons with 264  / 256 Tomei Pro cams. For around 350rwkws mark I will be recommending this turbocharger.
  • 3 weeks later...
Some results to share, This time is from Justin's drift car running with one of our ATR45SAT ceramic ball bearing turbocharger.
R33 GTST unopened engine.
HyperGear Atr45SAT Ceramic ball bearing turbo
6 boost manifold
Turbosmart 45mm Gate
Ebay 600x300x100 Cooler
ID 1000cc Injectors
460 lph Fuel Pump
3 inches turbo back exhaust
Haltech ECU
E85 fuel
Car made 397rwkws @ 21psi on a conservative tune for stock engine. Should see 420rwkws at full potential.
I would high flow the factory turbocharger using a ball bearing core with a G2 or a SS15 profiled wheel sets. the SS15 is a better choice for power and response.
For the best result use an Rb25det turbo. For a Ball bearing, billet wheel Ss15 profiled highflow looking at $1500 to complete including oil line.
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
