Most i seen was 266kw from my car 25psi dropping e85 and that was with the larger rear housing .86
Stock bottom end sr but
I would reccomend going the atr28ss2 in bb with .64 rear housing more responsive due to the smaller rear and i made 280kw with this
On a built motor with larger cams and custom exhaust manifold i would see it making 300kw
Action Dan: Yes. the factory exhaust manifold is a restriction and SR needs cams to make power. Plus your usual free flow FMIC, induction and exhaust.
Ask tao im sure he can arrange that
Most results ar from rbs but usually all in by 4000rpm and there only running t3 single scroll
Twinscroll will help alot hence why evos get away with 300kw turbos but are still responsive
This particular SR20det engine is something built by forcedmotor works 4 years ago. It run one of our ATR45SAT turbo compete and won WTAC Open class in 2016 and is still a current world record holder of the fastest SR on Wakefield. Its on a single T3 scroll manifold running external gate, and that pumped 400rwkws on E85 fuel, 28psi by 4250RPM. Far as I know its just a standard rebuild, no VCT with forged pistons with 264  / 256 Tomei Pro cams. For around 350rwkws mark I will be recommending this turbocharger.
  • 3 weeks later...
Some results to share, This time is from Justin's drift car running with one of our ATR45SAT ceramic ball bearing turbocharger.
R33 GTST unopened engine.
HyperGear Atr45SAT Ceramic ball bearing turbo
6 boost manifold
Turbosmart 45mm Gate
Ebay 600x300x100 Cooler
ID 1000cc Injectors
460 lph Fuel Pump
3 inches turbo back exhaust
Haltech ECU
E85 fuel
Car made 397rwkws @ 21psi on a conservative tune for stock engine. Should see 420rwkws at full potential.
I would high flow the factory turbocharger using a ball bearing core with a G2 or a SS15 profiled wheel sets. the SS15 is a better choice for power and response.
For the best result use an Rb25det turbo. For a Ball bearing, billet wheel Ss15 profiled highflow looking at $1500 to complete including oil line.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
