  • Replies 615
Posted Images
i had a full lock accident... snapped the hub just under the top ball joint, top and bottom control arm, snapped the castor rod and busted the rim.. it was under full lock and jammed the wheel up under the floor.... i dont think my steering stop saved me from doing any damage :P
Of course, if you're turning anywhere near that much, you've lost control of the car and are better standing on the brake.
I agree with this.... But John's mechanic Chris said that when he drove it, upon initiating a turn, and coming close to the normal steering angle lock, the steering wheel to PULLED towards the rest of the way, jamming the toe arm against the LCA.
That's what worries me.
Yeah, because the friction in the direction across the surface of the tyre is higher than along it, thus forcing it to turn (if the angle is available) but considering he would have driven it around the street, probably doing a u-turn or two, these would be greater steering wheel rotations than those seen on the track.
hmmm, well that is what normally happens, the tie rod end contacts the bump on the lca. but to get there would be like 2 full turns of the wheel or more. never going to get anywhere near that on the track. having driven a few cars now with the ikeya tie rod ends and the lca's i've never felt anything like that.
I think probably the best idea would be to weld on a little stop if it's a concern. don't even have to weld one you could fashion one out of some alloy and retain it with a hose clamp or similar.
and again, in an accident scenario I don't think those stops will save anything. as the tie rod smashes into it something's going to break. stop or no stop. :P
I do agree it would probably be good if there was one, but they must have a reason for leaving it off. I will ask them about it.
Yep... understand all that.
I was really looking for feedback from those who have fitted these same parts, and what they did (if anything) about the issue.
hopefully mark or russ will chime in, or justin, or dave. they all have ikeya front LCAs and a couple have the tierod ends too. but i don't think any of them have done anything to it and to my knowledge none of them have had any problems.
Also interested if they had to cut down their tie rod ends as well... Duncy Dinosaur's comment about them looking very long is a good start, because truth be told, I was a little scared when I was told that they were cut noes.gif
Haven't played with the LCAs yet... I'll report in to see how much we can wind the buggers out when I get to play with them :P
I went for the Cusco -10mm arms, which in conjunction with the standard position LCAs, gives about 3 degrees neg camber
oop, that was me posting as fatz.
anyway what I meant to say:
mark berry just called. he said stop being a big girl. there is nothing to worry about. if things get back your shiny tie rod ends will just smash their way into your LCAs, just like standard... :P
How much camber adjustment do the LCA's give you? What size front camber arms did you choose also?
combined with adjustable UCA, or the 10mm shorter ones merli has you can get heaps. like more than 5 degrees neg which is about all you'd ever want.
Hey mate I have the LCA's and tie rod ends on my car and have not done anything to them and not experianced any problems whilst driving around although I have not had the car out for its first track outing yet (where you would be unlikely to have a problem) I have done around 1000klm's driving without any hint of a problem so I wouldn't be concerned mate.
Edited by dazmo
hey mate, i also had some full lock issues on my car, the tyre would touch the castor rod on lock. I made some steering stops to prevent it, but found on my track day i never got near full lock anyway, well except when i had to turn it around on the grass to point forward again....... :D
i know its not the same as a 4wd but just what i found.
Thanks for the feedback guys...
I'll report back after I get the new clutch drive the car.
Re cutting outer steering arms we had to do this as they had bottomed out and the wheels were still massively towing in. With different offset and narrower tyres or pumped guards, teh lower control arms could be extended it would be ok. Cutting them was not a biggy and gives user the option as too short is worse.
The lack of steering stop is very not good as the arm over extends then comes back on itself, potentially damaging the rack and drive shaft boots. It can be fixed by welding a post onto the lower arm, which Ikea F should do.
Thank you John for pointing out a basic fundamental.
PAS systems are not designed to be over extended past a prescibed length. The factory always leaves a little in reserve. When you go past that point (and you will sooner or later) it makes the PAS work really hard to come back and like most GTR's the system is already working it's arse off. All you are doing is heating the system more which as we all know is not good and it does happen.
Just as a little experiment,,,try doing a full lock turn,,,I'll bet you have to pull the wheel straight.
Neil.
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
