Hi guys, just removed the head to fix a blown gasket, and i noticed three oil restrictors in the head.
I just wanted to clarify if these are standard ? I was under the impression from all the talk of fitting restrictors to limit oil buildup in the head meant there wasnt any at all to begin with ..
Was i assuming incorrectly , and you guys just modify them by fitting smaller orifice ones ?
Gary
https://www.sau.com.au/forums/topic/266059-oil-restrictors-pics/
Hi Gary
they are the standard nissan restrictors,
tap them down into the block and then install the new ones on top of them.
? Really?
I have no idea how to do the restriction mod, but it sounds wierd! Do you really just tap them into the block and have them float around? ahah
dont think they will go into the block as the hole goes a fair way down just pushes them in a little bit so you can install the new ones it wont float around
Never thought of that. Makes perfect sence!
Ah ok, thanks for the clarification Darren. Im not going to put any in , but i have the rear oil drain back to sump on its way up here. I just wanted to check if they were std.
Gary
Is this an engine out job? Do you think you could fire up some pics when its in?
I do a bit of track work in my R33, and havnt done either mods yet... bandad it with overfilling the oil slightly. And dont go quite as hard.
But it still makes me nervous!
Yeah i track my car also, just on a small circuit up here. Haha first round is next saturday !, wonder if i'll make it .... :P
This is just a head off operation.... You do need head off (or motor out) to fit the rear oil drain. Im getting it off Tufrx3 on here.... nice bit of gear.
I don't rev mine past 7000, but it still concerns me abit. But hasn't died in two years of racing it ....
I'll do pics when done..... Check the "automatic performance thread" for pics and updates.
Gary
Oh well, so be it. It hasn't blown up in 16 years street and two years + racing, i just see the rear drain as an additional help. And honestly i really just dont like the idea of limiting the amount of oil the factory deemed necessary. Just my personal preference. And i dont rev it over 7000 , which i assume makes a difference ?
Gary
thats what i was thinking,
plus they cost next to nothing from a machinest
Don't even need a machinist.
6mm black rod from the local metal supplies on O'sullivans beach road + a drill press with a 1.5 or 1.2mm drill bit and you have a restrictor. :thumbsup:
Gary,
Sorting the Nissan oil issues begins with the oil restrictors. Second... I personally prefer venting the sump rather than the mess of drilling/tapping the head for an additional oil drain especially if its being raced.
Fastrotor... My issues with excessive oil occurred over 5000rpm and 95psi oil pressure with 2 x 1.8mm oil restrictors.
It really depends on the oil pressure and setup you have if your going to experience problems or not.
I now run a single 1.5mm up front front and blocked rear with stupid hydraulic lifters. Zero issues.
Edited by TheRogue
Thanks for the tips. I can whip up a restrictor myself no probs.
The oil drain im using is a shrink fit into welch plug hole.
So you guys are that concerned for my motor, totally stock top end, 7K factory limit...... you really want me to go restrictors , ie its that close to a problem ??
I have hydralics still and VCT ..... so there is only the 3 restrictors to do ?? I assume i'll leave the vct one as is, and reduce the other two. ?
What size are std , 1.8mm rogue ?
Didnt anyone here try and search for this already and find SK's guide on oil control? That thread has everything you need.
search "Oil Control In Rb's For Circuit Drag Or Drift" - SydneyKid
+1
Size and location of restrictors is dependant on head and oil pump used aswell as intended application.
Youre all forgetting its a standard engine? Why would you need restrictors with a standard oil pump? You dont have any extra flow or pressure...nor will the standard pump empty the sump as quickly as an aftermarket pump would so why limit supply to the head?
I hadn't read the thread yet as i only posted this to show what i saw and ask if it was stock or not. I initially had no plans to add the restrictors.
Upon reading SK's threads first few pages and from alot of suggestions to do it from you guys, i'm going to block off the center feed only. Im not going to restrict the rear one, as i figure halving the supply is enough in combo with the rear head drain i have coming. Coupled with the std pump, and std rev limit. I feel this is a reasonable compromise.
I have some copper welding tips here close to 6mm i can sand down to fit (using a drill to keep round) , then solder up the center hole. Easy.
Gary
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
