  • Replies 43
Posted Images
haha yeah, toyota charger run by the haltech via NOS control (load rpm etc) then via a differential valve into the cooler, when the turbo boost exceeds the charger boost it is business as usual.... of course everything is also compounding so boost builds very quick. The charger drag seems to rob about 10-12rwkw from the top end. A few hours on the dyno and the boost switching/ load point is almost impossible to pick which was a big suprise for both of us.
The graph above of the the 2 rb30's is actually the same car before and after.
I have NEVER been in a car that builds boost and torque so rapidly other than BIG dollar supercharged v8's, its a real credit to luke.
Toyota supercharger....? I am guessing that its the SC14 from the 1GGZE which has the electric clutch.I would love to see pics of this one.I am interested as to why it loses 10-12rwkw in the top end as my understanding is that the Toyota Charger is totally disengaged much like an A/C compressor when switched off.
why use the sc14, if it's CMRS. its more likely to be a M90 or M62 off a calais or ford lightning.
cause all that extra torque cost $200 and some forward thinking on lukes behalf :) oh and a few six packs of jb.
small rear housing stock cams
1.6 bar for 350rwkw
thems alot of boost
RB30ET
To many turbs, its actually GT3582R 0.82 rear housing with a 0.5 front, but the dit function wont allow me to fix it.
Oh so this is a real rb30ET not a 3litre 25/26 !! Wow, thats cool.
Does anyone remember, maybe zoom mag about 5+ years ago , they had a RX-323 with a 13B Turbo, with a SC14 clutched on side as well, running haltech too using a throttle body being switched somehow. Can't remember exact details, but it used positive switching throttle plates.
Trent, how does old mates valve work ?
Gary
yeah i did first think toyota, but thought it would be a bit small in this case. pics or a diagram would help out here, as i cant visualize just where the valves are or what they do in this case (bundy probly isnt helping this lol). im guessing its run as a straight compound system with a valve to bypass the supercharger when the turbo is making more boost than the supercharger?
urtwhistle: reason for using the toyota charger in this case would be for the ability to 'switch it off'
sounds like a very well thought out system, especially in the way its being controlled via 3d mapping.
fastrotor. that little grean thing was great, i have the magazine here somewhere. but i think it was overcomplicated with valves etc, like this car may be....
if i was to do it, i think it would all be fixed, no valves or tricky sh*t like that, too much time spent for probly not alot of gain...
any chance the owner of this VL will let you put pics up?
Edited by VB-
Gary
it is super simple, i will take pics next time its in.
Simple y pipe between turbo and charger, the turbo inlet for the y has the valve in it..... very simple and CHEAP.
What a coincidence....a member on NS is using the same supercharger and same turbo setup on an SR with a VVL head (two cam profiles and can't throw rockers) which he started back in November
http://www.nissansilvia.com/forums/index.p...t=0&start=0
Edited by juggernaut1
RB30ET
weeeeeeeeeeeelllllllllllllllllllllll
in that case it actually is an achivement
in a det sounded average
is it in r31 sound very familiar
Haha slapping toyota superchargers on the side of anything and everything goes back way further than november last year :D we did a td04, charger and twin draw thru su's back when i was an apprentice on a 4k corrola (easy as head was non x-flow) ..... around 1994 i think and i know i was just one of 1000's back then even. I even think rod hadfield sell kits for most aussie engines.
plus he is definately not a ns.com reader or poster... no self respecting person is anymore.
Edited by URAS
plus he is definately not a ns.com reader... no self respecting person is.
True that.....I remember back in high school a couple of my mates did it to EA falcons...made about 200rwkw with nothing more than a rising rate fuel reg and a decent exhaust with 6-7psi of boost.
Hhahahaha at the NS.com Comment...made my day
That would be great Trent, thanks.
But i can't help asking , how does he switch the valve open, (ie solenoid, stepper etc ?)
Once turbo valve is open, i assume you can't turn the super off , as i assume air would try to flow back out thru the super( turning it backwards i assume, not sure if this is possible in a positive displacement charger????)
So even thought the super is outflowed by the turbo once above operating speed, i assume the super is kept on just to stop air coming out,(hence your comment on top end Hp loss) and i guess its airflow would add to the total flow anyhow since its positive displacement ???
Oh, and how does the turbo go with its surge limit when spooling into a closed throttle ? He could add another valve that recirculated the air back into the front of the turbo to make it spool up quicker.... like the S6-7-8 rx-7 does with the bigger of its twins.
Lots of assumptions on my part.... am i close ?
Gary
Edited by Fastrotor
i was thinking about doing this setup for a while however I am now capping the money spent on my car so its not going to happen. good to see how well it works
Why?
An rb30det has enough grunt down low already.. and by the look of the graph, he has the same down low as any rb30 det.
When I drive my rb30et I feel the pain cause it's a laggy crack whore....
I would go as far to say this bloke would have been better off just going twin cam and enjoying the power.... as opposed to having f**ked around to get the same power and response as a twin cam.
Point is, for a single cam this is awesome....... for a twin cam, very average.
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
