Snowy/Bris, what program are you using for editing the POV film? Do you have to convert them to .wmv files first? Mine is not cooperating...
Also, with the fuel cut did it just stop the car completely and require a re-start, or did it regain power again after a while? Seems quite dangerous to just be rolling around!
In your defence Snowy you can clearly hear and see that your foot was on the accelerator and brake at the same time. For that to happen on the limit would alway result in an off. Having driven one of those before I know that without race shoes you have no hope of hitting the peddles right.
I once borrowed the old mans Lancia fulvia sport to go to basketball in... I had chunky bball boots on and after failing to stop at an intersection because I stood on all 3 peddles at the same time I went back home to get some better footwear... that was scary enough I can't imagine doing that at Spa in a Caterham... your a brave man
it's nice having peddles really close but only when you've got the right shoes on!
Dane I just use Windows Movie Maker to edit mine, very easy, just open it up and drag the file in.
It's strange, the laptop is a few months old and has plenty of everything to spare... must just not like it for some reason. It's a real pain! I'm going to blame Vista :P
Actually - the lappy that turns the pictures pink runs Vista. I've also tried using Adobe Premier Pro on that lappy and it imports the video's upside down! (Go figure).
This lappy works fine and its not as powerful as that other one - but it runs XP. So....
Hmmmm, who knows then??! I definitely think it's a vista thing though, it's very glitchy and gives me heaps fo grief. I'll try and run it on my other old laptop and see if it works.
Out of curiosity, how much were the R400's to hire at SPA? And are you being re-converted to RWD after all this AWD cheating?? :P
Spa wasn't cheap - it was basically $6K for the car and 2 days of track time (So it was $3K ea.) - but which included all the fuel, tyres (we went through 2 sets of front Avon Race tyres in the 2 days and the set of rears were ready to be tossed as well!) and all the coffee, cordial and biscuits you could manage. It was open pit from 9am - 6pm both days and you could do as many laps as you liked. (Although they did ask we try and keep it to 40mins / hour to give the car a rest).
You could do it with 4 of you and still get more than enough track time - we sat around doing nothing for a good part of the time simply because it was 35degs so we were exhausted.
That doesn't seem like too bad of a deal considering the tyres/fuel etc in a properly quick car like the R400, it's actually quite good if you were to spread it over a few more people. Pity about the airfare to Europe :P
I reckon that's pretty fair. $1500 per day for each of you. that's a lot of track time. hey a single set of RE55s costs more than that and to use 'em you still need a car and a track. so putting it thaty way it looks good. :P
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
    • Wrinkle black will be a thing for both
