thanks heaps chris :] yea pretty happy with the day, the time of 58.05 on natsoft is incorrect as my GPS and video both agree with each other. old fella mustv been too quick pushing the button.
also on lap 3 of the 2nd vid split times indicate i was on course for a 58.18 for until i made the mistake, bugger.
Edited by scooby36
Ive always known Lakeside to be a high a speed circuit but thats the first time ive seen the speedo on a vid too, thanks Callum!
and just saw natsoft too - fastest lap of the meet - top work!
Do you not watch my vids Chris? lol :P
..... above on a very worn set of O3G's. Note the coner speed difference especially on the turn onto the straight Cal!
Edited by Marlin
thanks heaps ben, good to see ya yesterday.
watching mine afterwards i am relying too much on safe understeer and its probably costing me time and killing my front tyres. i will adjust the balance for next time.
looks like the aero helps my mid corner speed a fair bit compared to yours.. weights being about the same 1190 no driver? and i have a lot of tyre too, 235/255
It's a fantastic little track Chris, you need to find the time to get up here mate :)
I'm 1240 no driver from memory when I last corner weighted it.
Mine's screaming for a front splitter, it improved with undertray, splitter hopefully a step better. If I can get the front to tie up a bit better I can wind some wing back in on the rear.
Love it ^^ , looks like it wants to lift the tyres off the ground under hard brakes!
and man toffy the amount of lock you need to wind in to turn that thing, im getting tired just watching !
explain the gearbox.. simple 3 speed yea? looks fuggin fun but hard work!
yeah three speed (think of starting in 2nd and that's about it) , i need to adjust it a lil better so i don't have to do a z to go from first to second :blush:
Toffy from 8:00 onward is madness. Cars all over the place.
yeah that whole race was like that, it got worse in memory , the top 8 cars ar within 5 hundredths of a second of each other in memory (although it doesn't seem it in the vid ). it all comes down to qualify/start line take off pretty much
Edited by toffy
They are nice vids. I cant help but think that the footage you are getting is better then what I am getting out of my Radcam...will have to try some of the settings on my thing.
Also, do you know where the timing beacon was located on the weekend, by my vids I was doing 1:07-1:08s on the short track, but I suspect I was backing off after the finish line and I suspect the beacon was on the back straight now that they have me 6 seconds slower?
The timing was screwed up on the short track. Winton timing gave me a 1.10.x, racechrono gave me a 1.08.x and video gave me a 1.08.x
The long track timing was working correctly though.
As you say the beacon may have been somewhere else for the short track....?
I use the Go Pro HD's in centre metered mode all the time. This means that it takes light readings from the centre of the video and not from inside the car.
I'm cutting the vision of mine at the moment, but this is in my brothers car (white 33 gtst).
Got a couple pieces of lightning in the video, crazy stuff.
Watch out Stagea it's coming for you!
Yeh, its doing everything pretty well. I just need more seat time and need to get the general balance back to how it used to be which is to make it a bit pointier so i can drive it a little more on the throttle mid corner and get some better drive out of corners.
What is done to the front end of your car? It seems to need more steering angle then mine...but that could be tyres?
Good vids guys :thumbsup:
Great to see the silver beast in action Troy. As for Richos steering angles...maybe its a 33 thing as mine seems to require a fair bit (will have to check my winton footage to compare) so much so that it feels uncomfortable to keep my hands on the steering wheel in the same positions
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
