What turbo/ 's are you going to use ? Interested to know as I have similar 2.8 build being done here in Japan by HKS.
They were reccomending HKS 2830's with the V Cam and 2248/274 cam combo. Supposed to idle pretty standard but boost comes on real early and pulls all the way to top RPM..I went for drive in one of their customers gtr and was bloody impressive.
Mines at a stand still at the moment, still waiting for head to come back from the NAPREC
Edited by elrodeo666
  • Replies 103
That was supposed to be 2835 turbo's
V- Cam unpacking
I have always found the unpacking process fascinating, so I have documented it with these photos to share with everyone.
Thank goodness Benno has worked out how to install it. The instructions are entirely written in Japanese!
dont mean to sound like a retard but is the HKS vcam kit essentially the same thing as the RB25 VCT? variable cam timing?
sure the RB25 setup you can't touch / tune etc, but the same logics, that is, a variable cam timing system - cam timing that changes, with load etc
A set of off the shelf Garrett 2860R -5s will be installed.
In Cam as per V Cam Type A setup - Valve timing 90-120 degress, valve lift 8.6mm, duration IN 248
Ex Cam - 256 valve lift 8.7mm
It should be interesting how much boost these will develop in the hands of the maestro. The secret is in the rest of the package so I am led to believe. The truth will be told when I take my first test drive once its completed. Car is in the workshop atm.
You are spot on paul r33. If I put a RB25 head on a RB26 bottom end and get someone who knows how to put it together, then I will essentially get the same result without the HKS badge!
Sneak peek:
post-32660-1243148737_thumb.jpg + post-32660-1243148843_thumb.jpg + Dose of Racepace Magic
= Total Awesomeness!
I saw this beast finished @ Beno's today, when dropping mine 32 in & picking up Pete's 32.
This 34 looked very clean & crisp. Good Luck with car bud, seems u pland well & workd hard to achieve a fantastic result.
Keep us update..
:mad:
so its just the intake cam that has the VCT yeah? I would imagine this would be much more efficient than the 25 VCT as you can tune it right through the rev range not just switch it on and off
Sweet setup, so its nearly finished? make sure to post a dyno chart when its done:) will be a response monster!
I believe my car is next in line... I should have bribed Benno to drop that stroker crank into my build, you would never have known;) lol
No dry sump? :P
Dry sumps must be a NSW thing. As far as I've seen at the track, there is not one dry sumped car in Vic, however we never seem to see oil starvation blow ups either.
It sure looks sexy with the pumps and all, but is it really necessary for club cars where a well made sump does the trick?
There sure are some monster RB's in the build right now.
Glad i know of a couple that are NSW based so you Vic guys dont hog all the fun hahaha
Seriously though, great setup, looking forward to seeing the results :P
No dry sump is planned. Just a larger capacity oil sump with High performance/high flow Tomei Oil Pump. In fact the V Cam needs oil line to work properly and HKS does recommend a higher capacity Oil pump.
That does look like a fairly simple system, I guess yes the principle is exactly the same as the 25 VCT, oil supply, a solonoid to switch it on and off...this is awesome!
The thing I like most is the HKS POWER rocker cover. Its very very special, and they even give you the little red V-CAM badge!
This car will be insane...considering Aaron's 34 with the 2.8 and -5s made 350kw at 3,500 rpm? and 450 at like 7 something? (Cant remember exactly).
Built by the same genius plus the V-Cam....I really cant wait to see the graph...
Really good work on the pics Matt, its like were all opening the box ourselves! Except we dont get to touch and do other naughty things with the parts :)
I must admit Ben is like an eccentric craftsman (no offfence to him). He has good enough reputation for him to be selective with his clientele. And no he did not shake his head when I approached him with the job. Its for other reasons which will come into light in the near future.
As for turbos, I can't get hold of any Garrett-5 as they are on back order world wide. I am considering a set of HKS 2530s or Tomei ARMS B7660 now. But just for the HKS or Tomei brand will cost twice as much as the Garretts off the shelf. :P
Seeing Benno tomorrow
Dont mean to do a thread hijack
I'm in the same boat..once I made the decision to go the -5's and ordered them up, been waiting a good month or so and looks like awhile yet. Glad my head is taking forever and everything is at standstill.
If you want to spend some coin, most guys here running the V Cam go the HKS HKS 2835's with the and 248 In /274 Ex... they are beasts to drive, absolute weapons but pretty exxy.. I could get you bit of a discount thru HKS if your keen. I initially had this plan but went the -5's as was just after something near the 600-650ps margin. The HKS 2835's and V Cam would be easy 700+ps. The ones I have test driven have been 700 to 800ps..
What computer unit you going to run. Reason being there is another bloke in WA dunning Apex Pc and having major dramas. I had a talk with tuning maestros guys at HKS and they reckon anything other than Fcon Vpro and mdel before you will be pushing shit up hill..its doable but you will have a hard time trying to sort it out. Its typical HKS, all their stuff is made to run hand in hand and not with the competition.
I'm trying to suss some tuners in oz who would put up their garages for a week or 2 while my mate comes out and does some tuning but there is the whole political side with HKS to work out yet. Right now its an idea but we've put it on the table here and see what happens.
This was a GTR33 that had limeted edition V Cam
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
