I use ETM.
One he's local to me.
Two, he's always looked after me, and never bullshits.
Thirdly, I currently do have a 6BOOST manifold on the car, and the welds from ETM are so much nicer. As Kyle tends to finish you get "holes" in the welding... Not an actual hole, but a weak point... ETM manifolds, you don't.
where is a pic of this new ETM 100 series design which stops boost creep? would be interested to see, however the website seems a little light on detail
I don't think the new design would be rocket science. A flick through Maxiumum Boost will show you having a wastegate come off the collector at 90 degrees to high speed gas flow is one of the poorer ways of effective wastegating. Simply any shallower angle would be an improvement. Hence why when I ordered my 6Boost manifold (before I bought the Full-Race item) - I requested it be made without any wastegate provision - so that I could customise the wastegate position and angle.
Edited by juggernaut1
I dream about your Full Race manifold......
Can you ETM guys post some pics of your manifolds and inside the collectors, I would really appreciate it. Both the manifolds look good but it's nice to hear feedback from buyers.
Here's a post I made in my build thread ages ago.
Picked up the new manifold and modified exhaust housing today. Both the manifold and exhaust housing have been coated with the latter being modified to accept the 50mm Turbosmart Pro Gate. They look sensational. The collector design, the quality of the welding and the coating are all great. Leigh from Extreme Turbo Manifolds does exceptional work! Couldn't be happier!!!
Completed assembly:
Collector:
Exhaust housing modification:
If it has this plate, it rocks!
Beat that!
Freshly coated:
yeh...best way to control boost...straight off the exhaust housing like 2rismos pic displays...i did the same mod to my road car with the standard cast manifold and again on our race car with kyles manifold. Fixes boost creep everytime! Some people question if it has an impact on response because your disrupting the flow in the housing, but having had both setups (off manifold collector and exhaust housing) several times, there is no noticeable difference on track.
Both make very good parts.
Neither of them invented the merged collector.
I was making merged collector manifolds and merged collector split pulse manifolds 10 years ago and I didn't invent the merged collector either.
I have seen pics of turbo setups from back in the 70's with merged collector manifolds.
I am yet to see either of them do a true split pulse manifold. That’s not to say they are not making them I just haven’t seen one from them yet.
By true split pulse manifold I mean all exhaust gasses from opposing cylinders kept separate all the way to the turbine and wastegate, or two wastegates used.
If they don't make them yet ask them too. They both have the ability.
  • 5 months later...
Both ETM and 6Boost do true split pulse manifolds.
Has anyone used one of their single low mount manifolds? interested to see how they look...
this is my 6 boost lowmount manifold, i just managed to mount the gt35 with minor mods to the engine mount on my 33
the only problem that i noticed was that the manifold lost the blackness it has when first bought and it is now a greyish colour
how much do both of these manifolds retail for ?
the best manifold i have ever seen in my life is of a r31gtsr only 400 made lobster style my mate has 1 it is a piece of ART Marky at E.T wanted to make them but after playing with it recons the collector is just not possible.
Sounds far superior to any 6boost and other no name manifolds i have ever heard !
honestly 6boost and ETM are probably the 2 best known dedicated manifold builders in aus and both make great product. I have more first hand experience with 6 boost manifolds but I don't have anything bad to say about ETMs ones either. call them both and see which one you like the sound of most. or maybe just flip a coin. you will get a good result out of either one.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
