  • Replies 55
Posted Images
I've been keeping track of my fuel consumption on my iPhone...
Because of work I'm also making lots of short trips of about 10 min / 2 to 9Km every hour or so... ...I think I got around 600Km on a GOR cruise once and around the same going up to Swan Hill... ...But that was before I started recording my fuel...
i used to get approx 450km (30km of that after fuel light on) max. fairly stock auto. haven't had a chance to check economy recently as i've had it tuned, and still in the "honeymoon" phase :D
I don't think I've ever seen the fuel light... ...How low does the needle get before it comes on???...
For my car, it came on when the needle is like about 1/2cm or so under the E line.
& I only know this because when I picked up my car from the panel shop, they pretty much drained all the fuel out & I was driving on empty :( .
Thanx JamesK,
i got an autoban just down the road from me, ill pop in there on the weekend and see wat they can do for me about an o2 sensor,
hopfully that might get some more ks, if not, it cant hurt getting a new one :)
Forget autobarn, save some $$$ and time and order from HERE $77 and quick delivery.
I've never been brave enough to let it get that low... :(
Dont you mean stupid enough, efi fuel pumps dont like running dry.
Replaced the oxygen sensor tonight. Got her up on the hoist and laughed at why I even bothered putting it up there when the sensor was clearly visible from the engine bay. Then I ate my words when a seemingly 2 minute job turned into 2 hours. The positioning of the sensor is so damn awkward. Near impossible to get a grip on the sensor nut with a torque-worthy tool. My open ended spanner kept slipping...shifter couldn't get a grip...socket wouldn't fit over sensor. Didn't want to thread the sensor nut so I resorted to snipping the sensor wires in order to get an angled ring spanner over the nut (forcing me to get the new sensor installed or being unable to drive home). Still had no room to get any decent leverage though. Had to remove the heat shields from turbo and exhaust - the screws of which were rusted through and threaded themselves when I tried to remove them. Drilled some of them out and vowed not to put the shields back on afterwards. I was quite literally bracing myself against the car chassis while trying to unhinge that rusted piece of crap sensor. After every swear word in 4 or 5 languages she finally cracked. Putting in the new one took the other half of the 2 minutes I had originally intended to spend on this.
/end rant.
Here's hoping my fuel economy improves because my anger management sure isn't.
Oops should of posted up earlier I have an O2 Sensor socket if anyone nearby wants to borrow it...it does make your job a crap load easier as birds may have found out that damn thing is in tight!
My sky is on average on about 11.4L which i was happy with UNTILL my car broke down and started driving my brothers spare care, 1.8L Corolla. Geezzz, fill 40 L, done 550kms and i still got one line to empty. I cant belive the difference. You save about 7 dollars per 100kms. woow
In saying that, the car has no balls nor handling nor looks nor anything else. lol just a lil engine.
ive never seen a fuel light come on ever..
didnt know there was one
There is guys, trust me I was in the same boat as you guys but it only comes on when your needle is ON E like basically the light is REFUEL NOW!...haha but in the manual it says there is 7 or so lts left in the tank and even when your start to get at that level it will still start to fade on and off until I think about 5lt
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
