Hey guys,
Ok im not sure about this so i thought id ask,
Iv got a T3T4 turbo on my rb25det r33....its at 7psi at the moment... but the boost only kicks in really late in the rev range at like 6000rpm, espically in first gear,
So i was wondering if I brought a boost controller, would this effect what rev range the boost kicks in depending on what psi im running the turbo at? if i lowered or raised it?
Or is it my setup im running?
The mods i have to the car at the moment are the turbo, front intercooler, 38mm ext.wastegate, screamer pipe, ssqv bov on the hotpipe, full 3"exhaust and other stuff i dont think relates tho
I really just want a simple way to make it boost lower in the rev range if possible?
Thanks for looking guys...my first skyline so am learning!..loving it tho..dont know why i ever had a subaru legacy in the past haha
https://www.sau.com.au/forums/topic/271347-changing-the-revs-the-car-boosts-at/
6000 jebus...i'd just get out of the car and walk to work...ha well not really but probably think about it. I know with my blitz controller you can adjust gain to make it spool earlier but we're talking about maybe 300-500rpm range. I doubt if it will help you drop it down from 6000 to 2500. I think you may have to look into the springy thing that opens up for boost and adjust that or replace it? No idea what I'm talking about. I'm sure someone will be more useful.
by the way, did you ever get the car tuned when you stuck the turbo in?
what ECU ?
has it seen a dyno recently to see whats going on, air:fuel, ignition timing, etc?
to bring it on earlier ignition timing adjustments help, same with air:fuel ratio adjustments.
to do this you'll need some sort of ecu tuning, either full plugin or piggyback
apexi power-fc, greddy emanage ultimate, apexi safc+sitc, etc...
are u sure its not coming on to boost till 6000 rpm?
could be in dire need of a tune and the car is just sluggish as hell till high rpm?
does the motor sound to be running right?
no nasty ignition, fueling or timing problems?
full boost at 6000 rpm is far from ideal in a street driven car.
thanks for your replys,
Its got the standard ECU... and yea it is in need of a tune.... it back fires alot during gear change, and when i turn it on in when its cold it seems to missfire/be out of time for a while untill its warm when its idleing,\
It seems to be running rich, but when i pulled the spark plugs out it doesnt seem so, but it back fires alot
The car itself runs fine tho...goes along nicely, im not sure if its sluggish getting to high revs or not because ive got nothing to compare it to but u definetly feel the turbo kick in when it does,
I didnt install the new turbo so maybe it didnt get tuned?
Would a dyno tune fix this? and bring the boost in sooner? or do i need a piggyback or power fc etc?
Edited by R33 0wnerrr
problem 1 - stock ECU. You need to upgrade the ECU BEFORE upgrading turbo, so clear problem there
problem 2 - how can a dyno tune fix it, with a stock ECU? again, get a ECU FIRST.
problem 3 - what actuator/boost contol? If its just stock, no surprise there really... but again, ECU FIRST
So, go get a ECU, get it tuned with decent boost control and go from there.
Either way its a t3/4, a hybrid turbo that is highly likely to be a poor 'match' of wheels which wont be helping the situation and making it laggy that nothing will fix
turbo's are the key part on the RB's, spending $800-$1200 on a turbo is not enough, decent turbos start @ $1,700, so im willing to be your turbo is in the 800-1200 brakcet :(
He says 38mm ext wastegate, that could be a problem if that is leaking.
If you go to a dyno with the factory ecu they are only going to be able to adjust base ignition timing (CAS) and maybe your fuel pressure (if you have an adjustable FPR) Really what you need is at least a piggy back ECU or more preferably a full standalone (powerFC) so you can have it dyno tuned properly.
The other thing is you maybe wasting your time with this turbo.
If you just want something that comes on boost nice and early perhaps you should look at getting a factory RB25 turbo back on it? With the turbo you have now you could put some decent boost into it (especially with the aftermarket ecu) and get some pretty good power out of it. The standard turbo on the other hand is really only good for around 1bar of boost pressure, and will likely run out of puff when you get near redline.
Selling the turbo you have now and getting a standard one would probably result in having change in your pocket. Getting a powerFC is going to cost at least 1k, then dyno time at least couple hundred dollars.
It all depends what you want from the car and how much you are willing to spend on it.
Edited by daisu
Ok well i didnt know you cant dyno tune it in this situation with the standard ecu....
So i pretty much need a new ecu... a piggyback or pref a stand alone? what about getting the standard ecu remaped?
i was hopeing for a cheaper fix, guess not! :)
Oh and how do i tell if my wastegate is leaking?
Oh and will this be doing any harm to my car meanwhile?
sounds like you have no idea what goes in inside a car to get it running right, its ok - we all started at that point at some stage.
when i started i thought that getting the biggest turbo, biggest exhaust, biggest front mount and it will be good for 11's.
the things you'll need to run that setup properly is a full programmable ECU, fuel pump, injectors, coil packs, wastegate/actuator as a bare minimum.
you'll be running very rich up until the turbo kicks in then very lean onwards - im surprised you haven't blown your motor, i'd get a compression test done asap to make sure though.
Mate, i think that you should first check out the external wastegate before you go and waste money on a new ECU. It could be as simple as adjusting the wastegate or checking the vacuum line to it. It sounds like the wastegate is not closed.
When you start your car check if there is any fumes coming out of your screamer pipe?
Do you know what size the rear housing on the turbo is? and do have any photos of the setup?
regardless he needs a new ECU/remap because of what was said above.
Edited by SECURITY
Waste money on a new ECU ????
Sorry mate but it would be a FAR bigger waste of money to not get a new ECU. If its a standard one like he said that tune is out like all hell for that set up and more than likely will lunch the engine
Edited by GTR-32U
Well not knowing how much money he has to spend, or if he even wants to spend money on it, i just gave him something to look at before he goes and spends $1000+. Yeah a new ECU is a great idea, but if he can fix the problem quickly it would suit him alot better as he wrote in his first post "I really just want a simple way to make it boost lower in the rev range if possible?"
I brought this car with the bigger turbo installed already, so your saying because the cars running rich to boost then lean onwards and the general tune being so out that your surprised my motor hasn’t blown?
Yes I am new to this... and iv got to start somewhere though, just need to brush up on my ecu knowledge.... Basicly running bigger turbo, is what you need the new ECU for it to be able to be tuned properly to run right? does this count for any new turbo? or all aftermarket parts in general?
If like the post above said, that I get a stock rb25 turbo and swap it, can I dyno on the stock ecu I have now? or is that not recommended?
Thanks for your help guys...I appreciate it heaps
Its to do with how much fuel the ecu gives the motor, this is effected by how much air it has to mix it with and what timing as well, if you have a small (stock) turbo the standard ecu is set to give fuel steadily untill boost comes on, then it loads up more fuel because of the extra air being pumped in, it is set at certain points in the map and corrected by the air flow meter.
With a bigger turbo the whole map is different because boost comes on at a completely different point.
You have 2 choices really, get a stock turbo or a ecu and tune.
I'm in a simillar situation as you, r33 with t3/t4 unknown turbo hybrid which came with the car when bought and hits max boost pretty late..
in my car positive pressure starts to build at between 2000~2500, 10psi@ about 3000 and reaches full 16psi at about 4000rpm.. puts out about 240rwkw
thats with pfc and electronic boost controller tuned, z32 afm and nismo injectors...
its not the mose ideal power delivery curve, a bit more response can probably be had with a more aggressive tune with more IGT, but can't really complain since i dont know the specs of this turbo, all i can see/tell is it uses factory exhaust housing and new intake housing, and i'm suspecting its probably a budget turbo...
so yes.. assuming we have simillar or even the same turbos, this is what a tune with proper supportive hardware can get you
Edited by chiksluvit
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
