There is a reson why the German economy is doing well, car parts and service charges. Enjoy your three year wonder :D
I concur 800 for all new rotors installed
The old Prados and patrol all had f**ked rotor but I didn't car this car I feel the need to service... Just in case
I've gone soft
Towed my 34 down to Brisbane from Mackay (2200km return) with a 3L diesel Hilux. Done the job fine hills didn't seem to bother it too much, just used a little more fuel about 15L per 100km
See, I look at that and say ,"meh".
I've sold it now so can't be accused of being one eyed. But my hemi powered Jeep grand Cherokee Ltd averaged 19 bris-Townsville and return towing my race car n all gear...... and really was a superb tow vehicle. Loped along on cruise, seldom needed to kick down, and even downshifted automatically down hills to maintain speed.
And it'd run low 14's on the quarter even on 22's.
And it sounded tough and was a pleasure to drive.
Bloody reliable too once I sorted a few issues within the warranty ( but I'm damn fussy).
Good thing!
I'm under no illusion that it won't be a costly beast to keep running, but nothing else in the market with the same towing capacity appealed. I think the Japs do reliability the best, unfortunately they don't do style and interior finish at a level that I was happy with. If I'm going to drive a land barge instead of a sports car then I want it to be a killer place to be, and the Q7 is that. Pity it will be killer on the wallet too... :ph34r:
How's your going Fatz?
same.. mines had just about everything in the tray. wanna get a canopy for it tho so i can lock shit in it for those interstate trips where you stay in some questionable areas lol.
ftw mine uses 13.7 Lp/100 while towing fully loaded with spares, fuel, tyres sitting on 120
I have a 2003 GU III 4.8 Patrol - 5 speed manual. From memory I think it has the highest towing capacity from the Patrol range - 3.5 tonne or something.
Would need something like this to keep it going towing that weight though...
Falcon sedan with the ZF six speed auto. That's what I'm thinking of, under 100K klix, don't care if it is not the ideal tow car. Value for money, compact multi purpose car, can't see the benefit in a diesel at present given that they would cost more to buy, are not that much more economical if at all and with the CRD's maybe cost more to own. Falcons are unfashionable which = buyers market.
ZF's don't appear to require additional cooling for towing say 1900kg total but has anyone added a cooler?
Don't know what planet you're from but the diesel 4WD's I've driven have been massively more economical than the petrol equivalents (10L/100 vs 15-16 typically)
That aside, the Falcons are pretty good value and hard to go past.
Yeh, ZF has a engine coolant heat exchanger but I'm wondering if that is sufficient. On fuel economy, a couple of diesels mentioned above are said to do 14-15, BA - BF Falcons do no worse than that. Anyway, it's close enough not to be a factor.
I've gone soft
i used to work at audi artarmon... the amount of import brides who fill up diesel q7s with petrol is unfathomable. at 18k to fix, the husbands were never happy.
best tow rig I've used would be dads old cayenne turbo, but that was towing a 67 superbug with a stan pobjoy 1916cc in it.. so weighed less than ur dick but the aeros were quite horrendous.
I should be picking up a VT commodore with the 304 v8 should tow pretty well with heaps of off idle torque
Plus its servicing costs for 10 years will be less than a q7 for 1 year :P
lol
yea i have asked for the gbox oil and diff oil to be changed at the next service 100k
should hurt my ring
lifetime gearbag and diff oil in euro cars lol
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
    • Not yet quite as bad as what we've seen a Jim Berry clutch do in an R32 GTR though when it decided to cut a chassis rail in half... Still very very gnarly and a great reason to avoid.
