Yeah I would have to say that heading up the big hill coming out of the gong is a struggle for any car.
Up mooney mooney I can sit on 100 if I really want to but I usually do about 80 to 90 up the hill.
got to love the falcon
I'm talking all the hills on the F6 from Wollongong to Sydney, not just climbing Mt Ousley.
on the BA manual, beware of redbook, not all of its figures are accurate. From memory when i was researching all manual ba-fg xr6t had a 1600kg towing limit. Clutch and box don't like the strain.
also, i much prefer the having a lot heavier tow vehicle, just imagine what its like pulling up a 2.3t trailer with a 1.5t car when the trailer brakes fail.
or even worse even if you're halfway around a bend and you need to slam the brakes, chances are bad enough of jack knifing with a 4WD, youre nearly guaranteed it in something like a falcon or commodore.
  • 11 months later...
4wd all the way
if your trailers and car are close to your tow limit just add fuel and tools and your well over
not worth the risk
Sorry to bring back an old thread but i couldnt help but think how funny fatz is talking about safety. If i remember fatz car trailer was the thing of ledgend for being so damn dangerous even the tyre rack fell off one time and i had to weld it back up.
Mmmm death trailer was the reason I got my first 4wd
As a upthedatefor this thread
Q7 approaching 200k on the clock
Still tows like a mofo..loves 3 tonne out the back
Do recommend and for the f**kers above I think you can pick one up for 20k now
I must say I have been eying off a few v12 q7s as a upgrade recently
Why not the V10 Toureg, and pocket the massive difference in change? I've driven one of those towing a big arse trailer. Was like nothing was attached to it.
Excuse ignorance, but much difference between them?
v12 has 500hp
Have owned QE7 and TOUAREG V10, both very capable, V10 noise under load like rolling thunder, main difference besides size is that if you venture off road into slippery stuff , the VW will be pulling out its sister. Haven't driven V12 so cannot comment.
For under 20K I love my 4.2Turbo Diesel Cruiser. 2000 model.
Not quite as quick as Fatz pram, but if you do go off road it goes pretty darn well :P
So well that I sold the car trailer I bought to tow it so I can 4WD more instead :P
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
