This is a question many have asked.
I spent 2 years in Japan and before I went there I didnt even know how to change oil. All I did was turn wrenches for the Japanese in exchange for cheap cheap cheap parts. I once got an Rb26dett from a R33 for 400USD...
Anyways I was going on and on about my honda days when we used to build the crap out of a tin can and call it tuning, I did alot of watching back then.
I wanted to build a Rb25det and use the money from selling the 26 to achieve 500hp to the wheels with moderate cash less then 10kusd. Maybe around half of that.
I went on about forged this and upgraded that.
The Japanese guys scratched there head and said WHY!!!
They assured me a stock Rb25det on a stock headgasket was more then capable of 500hp. They said to add a accusump, and some injectors, a ebay turbo and tune and have fun...
I couldnt belive it but yes its true. How do I know? Because I did it and the engine is in my car right now. I blew the engine about 5 months ago but thats because I got boost happy and went up over 1.9 bar... oops my knock light got ignored because I wanted to teach a porche a lesson I won the fight lost the war.
Anyway back to the story. So here is what your RB can take relaibly:
RB20det: 350-400hp You will need a headgasket and might experiance lag of course you will need a turbo capable of getting you here along with a tune etc... But the engine itself is one of the strongest RB the Rb20det is stronger then both the Rb25 and 26... They just lack displacement.
RB25det anything under 550 is golden with this engine its solid as hell and has half the problems of its big brother the Rb26dett its just the Rb26dett has more upgrade potential and can strectched farther now the R33 versions are solid. The R34 versions have weaker blocks and the computer crap makes them a pain to tune.
The R32 have the oil starvation issue but before you go out buying Jun oil pumps and sumps and spending crazy money heres how the Japanese do it. Its called an Accusump it will cost you about 300usd that and a baffle and problem solved.
The Rb26dett is excellent in the R33 sturdy block, better design, usually lower mileage then the R32 version, less complicated then the R34 version and can be cross compatible with all Skyline chasis. There is no downside to this motor, in order to reach well over 600 the rods and pistons will have to go.
The engine can do 600 reliably with the right safety mods.
Accusump, baffle, huge oil cooler, GOOD TUNING!!! GOOD TUNING!!! GOOD TUNING!!! I cant stress that enough... Its all about your tune when going for big numbers dont practice on your baby go to a professional now your beater is a diffrent story...
This same information has been stressed before... You can do just fine with N1 oil pumps, and water pumps, you dont need Tomei, Jun, Greddy, they are overprices and good for another 1000rpm ooooh... An Rb is not an Sr it has the torque downlow to make you smile without high RPM...
Also for the Rb25det guys here is a little advice stay the hell away from high lift cams that take major head mods, the reason is because the Rb25det is stroked in a way to reject high lift cams even after the head is built up. For this reason you lose low end power and without a Jun oil pump ie 1500 dollars you will blow your motor to get the most out of your cams, 256 to 260 lift is more then enough...
If you feel you need 272's then its time for a Rb26dett... You lose power where it counts in a 25 with huge mods...
No need to stroke your Rb26 to an Rb28dett. Michia a freind in Japan has 900whp on an Rb26dett with just forgies and bolt ons and he has lost no torque and he doesnt have a jun oil pump or anything like it he uses an N1...
He also has poncams imagine that... He has 2 big twins and a GREAT TUNE!!!
Save yourself some money and spend the money where it counts... Support mods...
Research accusump it can be your best freind and save you thousands...
  • 3 weeks later...
OEM Nissan headgasket will be fine unless you want something thinner to raise compression..
..Because controlling the amount of oil that gets pumped into the head has nothing to do with it.. :P
+1
Particularly when they clearly have access to Jap parts for "cheap cheap cheap."
If I could get and RB26 for around $700 I'd probably wring its neck till it died then go get another one too....
  • 11 years later...
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
