Hi All,
I've had a few members ask me about the progress on my rb26/30 build for my R32GTR so i thought i'd add this thread.
I started my research back in late 08, got the ball rolling in feb 09 & after 4 months i have reached my destination with 350km on the clock. As they say, good things come to those who wait (i hope).
Here are my specs:
'NISSAN' rb30 block (note the word 'NISSAN' not holden or forklift hehe)
RB26 head porting by ProEngines (over 10 hours)
match ported exhaust manifolds by ProEngines
Garrett low mount -10's (combined rating @ 920hp)
RIPS custom sump (extended with baffles)
RIPS diff adapter plate
RIPS oil pick up
RIPS inspired modified catch can (return to sump)
JUN crank collar
ACL race bearing set
Cometic head gasket
Mahle piston & ring set
Argo rods
Camtech/Kelford billet cams (a bit of NZ flavour)
Performance valve springs (a bit of Aust flavour)
ARP main/head studs
N1 oil/water pump
HKS intercooler (120mm?)
Sard fpr
Bosch 044 lift pump with 2 external Bosch 044's & surge tank
PFI dual entry fuel rail (to accommodate larger 14mm entry injectors)
Delphi Rochester 1000cc injectors
Ross Metal Jacket harmonic balancer
OS Giken cam gears
Jim Berry 4000lbs race clutch (good timing whilst the engine was out, twin & triple plate was doing my head in)
Nismo engine/gearbox mount kit (good timing whilst the engine was out)
Blue silicone heater/intercooler/radiator hose kit (good timing whilst the engine was out)
52mm dual core alloy radiator
Power FC
My run-in tune results came to 270.9awkw @ 6500rpm on 10psi (cams are still set @ 0). My goal was to crack over 400awkw with strong midrange delivery, after i do my run-in km's with higher rev limit, boost & set cams im sure this will be achievable :(
i am also contemplating with running E85, my tuner suggested "lets see what we get with 98 then make a decision"
Just a quick thanks for the following people who put me in the right direction & put up with my indecisive 'qualities':
RIPS (Rob Ward)
ProEngines (Greg)
Dirtgarage (Paul)
N1GTR (Steve)
CRD (Andrew & Jim)
maybe i've left a few others out...in fact, i bet i have :)
regards,
Marko.
https://www.sau.com.au/forums/topic/277399-project-gozila/
  • Replies 477
no offence now but just out of curiositiy is it still fine to run Jimberry clutches??
i remember reading how they blew up on how loads with GTRs and othersuch..
i am and most likely wrong but just wanted to clear the air thats all sorry.
you hear good & bad with all clutches, however, based on pauls 470awkw drag car & 3 yrs of abuse it held up fine - apparently it is still 'alive' in his mates street car
if u drove a JB clutch u would be surprised, ive had an os giken triple & exedy twin which were both terrible (handbrake starts on hills in heavy traffic etc, you know the stuff that gets your heart pumping)
in fact i smashed 3rd gear in my other gtr which i think that triple plate was the root cause
https://www.sau.com.au/forums/topic/277399-project-gozila/#findComment-4691363
Nice work Marko, who put the engine together for you in the end?
hey nick - i had greg @ proengines build the long engine & i did the r&r (with workshop manual & correct torque settings)
that was fun although i must admit im nowhere near as fearful of the car though, the advantage of doing it yourself is taking the time & checking over everything, washing all the bits with a toothbrush
someone else i forgot to thank: Craved Coatings (Chris) for the top covers, intake paint & plenum powder coating :)
https://www.sau.com.au/forums/topic/277399-project-gozila/#findComment-4691374
did you get the sprung center or solid center version of the jim berry clutch? i was very surprised by how easy mine is to use compared to other heavy duty singles/twins i have tried.
https://www.sau.com.au/forums/topic/277399-project-gozila/#findComment-4691393
thanks - im driving it with the rev limit set @ 5000rpm :)
i can honestly say though it feels very strong in midrange delivery even on 10psi, the -10's start spooling quite hard around 3000rpm (that extra 400cc has made a massive impact on turbo response)
they seem to come on earlier than my gtss setup on the rb26
https://www.sau.com.au/forums/topic/277399-project-gozila/#findComment-4691502
Jim Berry clutch's are great. I had a Nismo GMAX Twin plate in my car and it died in 3 months. Put in a JB Full Monte Race Clutch and it has been the best clutch i have ever used, it feels light as stock and it has has put up with many slow rolling 30psi anti lag 3 gear drops and just asks for more.
Anthony Martook uses them in his race cars, results speak for themself.
Look at this youtube vid of one of those 375rwkw 3rd gear drops :)
www.youtube.com/upyas
Anyone who talk shit about JB clutch's are idiots without a clue. :) fin
https://www.sau.com.au/forums/topic/277399-project-gozila/#findComment-4691594
Im not a loyal JB customer as ive now jumped ship to NPC...but only because i couldn't see my trusty single plate holding 1000hp. My old clutch now been onsold again and is now in a 3rd car...what a top piece of kit.
https://www.sau.com.au/forums/topic/277399-project-gozila/#findComment-4691614
Lookin good marko! Now to get out, run some k's up and wind the wick up :bunny:
Last time u said it was due to sponsorship requirements
https://www.sau.com.au/forums/topic/277399-project-gozila/#findComment-4692485
f*ck off idiot...do i have to go into it...ok just for you.
Croydon Racing sponsored the car at the time...they wouldn't allow me to continue running a single plate with the power we were planning on running. They insisted i run at least a twin plate...it was something that was agreed was the best way to go.
Happy ?
Edited by DiRTgarage
https://www.sau.com.au/forums/topic/277399-project-gozila/#findComment-4692534
Happy ?
lol whats up ur shirt? if you dont like it paul u shouldnt put ur head on the chopping block
https://www.sau.com.au/forums/topic/277399-project-gozila/#findComment-4692546
    • To back this up, I'm always looking on the outside, seeing the level, and then opening it up anyway, as I'm worried the level I've looked at, is more so a scunge line. Then you end up dipping your damn finger in it too depending on the type of tank you're looking at just to make sure I'm not going insane.   PS, Mark, polish up the none moroso one a bit and then give it a clear coat. The Moroso one looks to be way shiner (not mirror polished, just shinier) and it'll still look weird with the two different alloys beside each other. Either that, or Id probably paint them a flat black...
    • Good old Orange Park hey... 😛   f**k I miss that race track
    • lo, it was a death trap. Good times. Got any Fatz Drift Day DVDs still available?
    • Yes, overthinking. Many PS reserviors are completely opaque. Our Skyline ones, for example. Have to remove lid, peak inside, swirl the dipstick, try to remember how to read it, etc etc. Normal. Radiator overflows are often sufficiently opaque and scunged up that you can't see the true level inside anyway, and have to open and have a peak. Besides which, I replaced the (massively expensive, even back then) plastic overflow in my Alfa GTV, back in the '90s with a stainless one that I had a good fabricator make up to be dimensionally same-same, that looks remarkably similar to the Bogan's Moroso one above, and I never suffered any particular paranoia that I didn't know how much coolant was in it.
    • Looks great, but I'm always concerned that it makes it difficult to see what level the fluids are at. Am I overthinking this?
