Looks the goods, only how the hell do you get into it? LOL, i would struggle to get in and out of that jungle gym :down:
practice. i think the best way is to sit on the intrusion bar with your feet in the car, then slide in. I will be putting a removable wheel in though.
the cage work looks great, i like the boxed front legs as well. I remember reading something about the intrusion bars had to be minimum 100mm up from the base plates on the front legs and hoop, is this true? or is it from the floor? or did i read wrong?
They must meet no further than 100mm away from the base of the leg/hoop.
And all intersecting bars must meet within 100mm of each other.
YT's old R34 we ran in 07/08 was like that cage, bloody hard work getting in/out! lol
Nothin better than pinching a nerve in your neck when getting in 3 minutes prior to a stage! lol, good strong cages but :D
Did that have the horizontal bar? I just cant seem to recall it cos there was so much room to swing your helmet back there?
Timmy, no, it didn't have a full diagonal, but rather two smaller diagonals behind each seat. They were welded about 50cm from the top and upper sides in the centre hoop.
I found a pic that kinda shows the bars....... and our intensity! lol. Just zoom in on it a bit.;
Deano, we run a PFC in ours, scrounged 2nd hand, but would love a Motec!
Edited by Marlin
I'm trying to find a PFC Pro to run in mine, will be a modified GTR one though.
YT said my cage is very similar to his R34's. Cams have now banned those small braces on the main hoop...they will let you run a empty main hoop though
Interested in what computers people going to be running with their RB20? I'm looking into running the stock one with nistune on it for my motor.
Most rb20 guys if they know it can be done will put in a RB26dett power FC. you cant go past one for ease and cost. untill you get into the top end nothing comes close.
they display knock - not many others will.
the hand controller is fing porn and handy.
if you run the rb26 one over the AP engineering item you can run the air intake temp sensor that will detune the car as it heats up allowing to tune the car more aggressively to temperature.
i could go on but im out of time.
oh and Not on the cage. i think ben got it made with a small opening so i cant fit in it as im getting fatter and fatter. lol
Oh yes i do remember now, the Stilo amp was mounted on it, shame that design has been banned
Damo, it's a 20 mate, just set everything the max and she'll be all good :P lol
haha, thats right they dont have enough power to knock.
jokes jokes
Nah damo they can knock all night! 5 days straight and then have a bender b4 finishing up!!! (hopefully benny will understand that one!)
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
