I started puting the seat mounts in on Saterday. I've cut the standard mounts out, and so far put the front drivers side mount in. used some 3mm plate as a base, and 25x25mm rhs to go between the sill and transmission tunnel. i forgot to take the cam on sat, so i'll try and get some pics today, and put them up.
some pics of new toys
Haltech Platinum Sport 2000, and Racepak IQ3 logger dash. Better value money than a heap of gauges, also neater and easier to mount. Also can kill the engine if oil/pressures drop (right foot dosn't always obay red lights)
Cheap carbon boot, slight damage in the top right made it much cheaper
I got my Navigators seat mount in today. Got it to sit really far back, pitty the exhaust was in the way, so i couldn't get it any lower
Also removed the ignition barral, and steering lock.
Damo started stripping the loom out
Also got a ABS unit out of a VY Commodore.
Very cool Ben, gee wiz your passenger seat is going to be a long way back. I mounted mine on the hump so the passenger sits a little higher than me but i will not have one very often.
What's the idea behind the VY ABS unit?
ABS is very handy for tarmac rallies. especially when your tyres have to last for 5 days. And the standard Nissan unit isn't very good (late 80's tech vs 00's tech). And ABS from a local car is easy/cheap to find from a wrecker, I only paid $110 for the unit.
How do you go wiring it up?
fair enough.. with a cage like that, i hardly think the extra few grams of steel would matter :D
i will be doing the same no doubt... as like you... i have a large sheet of alloy, sikaflex, and no a/c.
    • Hello Liam - HA - somewhere in flies - possibly I have an update, but I have been so busy, projects have taken a back seat to getting business back on track.  I will let you know the outcome, but I think I am going to go for the 8HP,  CHEERS.  ELVIS
    • Thanks Joshuaho96, yes - as someone else also suggested, the 8HP seems the 'smart choice' - HA - and ZERO to do with cost, but I am sure 8 speeds will be better than 6 speeds - HA - maybe.  I will purchase a new 8HP,  Thanks.  ELVIS.
    • Nobody said anything about getting a "...cheap Falcon box..."- it was JUST a question about a specific transmission.  And YOU may have a problem with not enough $ - HA - I do NOT - so please keep your comments like you are some financial guru to yourself.  BUT - much appreciated re the cost of a new 8HP and I twill probably be the way I go.  Thanks.  ELVIS.
    • Most people I know in the BMW world are swapping 6HPs for 8HPs. The 6HP has a big issue with one of the clutch drum bushings wearing out shockingly early which leads to them going into limp mode going into 5th/6th gear as the oil pressure loss from the worn bushing causes clutch slip. Even with the adaptations in shifting the TCU can't bump line pressure enough to keep the clutches from slipping and burning. I've personally looked at a 335d with 6HP28 with one owner and ~90k miles on it and the transmission adaptations were way out of spec and even though it nominally drove ok I'm confident it would have needed a full rebuild sooner than later. Other than that they're fine, but the 8HP doesn't really have weird issues like this to my knowledge and they're in everything these days so pulling them out of crashed cars isn't too hard.
    • There is an ABS pump and a few solenoids. You could trigger the front/rear solenoids with a pressure bleeder attached with a Consult 2.
