dash looks good boys... will be doing mine this weekend.
ive read that the 3m spray glue is good to use also?? yes?? no?? dont know?? should i repeat the question?? or is selleys qwik grip the only shit to use??
using pegs is a bloody good idea too... must get some of them yes.
the 3M stuff is good no matter what its trying to do. good product. i just use the quick grip because i have for years on interior stuff. I used to make hetic boot instals and trim them in vinyl and alike.
biggest 2 concerns is that it isnt to wet or think as it will seep through the fabric and that it will stick like buggery.
Nah its only fun when your running in/tuning/finishing off interior on the drive to scrutineering!!!!
But yeh good plan!
i heard that you was coming to lend a hand this weekend tim? it is a long weekend after all so even more can be achieved.
biig update
ABS mounts are now finished.
diff installed
modified heater box wiring, so it can be controlled by toggle switches.
Damo hacking up wiring
All the bits for the thottle setup
Bare engine ready to roll
Surprise HKS gaskets came with my RB26 plenum setup from japan
coolent bar, and air balence bar connected to manifold.
Adapter plate installed
Manifold installed
Throttles installed
modified coolent pipe
All installed!!!
Tein TP (Treated Pine) softest tein on the market
Now thats an update!!!
Out of interest, what are the engine mods limmitations for targa?
Origional engine and capacity
Origional head, but unlimmited mods?
Origional turbo?
In origional case ecu?
Model spesific- cooler? front bar/aero?
Unlimmited susp and brakes?
Cheers
Justin
Origional turbo?
Cheers
Justin
std capasity & block, but internals are free
pretty much free aslong as you don't change sohc to dohc, so porting, valvs, lifters, cams.... are free
ortiginal can be highflowed
ecu and wireing loom is free.
cooler is free up to 600x300x80, aero is from any model in the series (so gtr)
shocks and springs and brakes are free, buses can be upped to adjustible nolathain....no rose joints :)
wow so all that plenem shit is off a gtr n u put it on an rb20 ? how much it cost? and how long did it take to modify ? looks f**king awesome
took a while to do, cost me $350 for the plenum from japan (cause local guys rip you off), not sure on the price for the parts, i'll have to look back and see.
Nice work you two :laugh: Looking excellent!
I got a GTR rear diff cover on the weekend, that should be be a simple bolt on to allow the fitment of the rear ABS sensors correct?
unless you have a gtr subframe it won't work, as the gtr runs 2 studs to secure it to the subframe, and the gtst runs 4 studs. I talked to benson, and we can't run a gtr subframe (even tough they are identilce bar the diff mounting holes)
shocks and springs and brakes are free, buses can be upped to adjustible nolathain....no rose joints :no:
Thanks for the info big fella.
I'm diggin the black powder coating too. I'm seriously considering a similar theme applied to my 26 greddy plenum...
Could you post up a pic when you have i all plumbed up under the plenum.
Cheers
Justin
Edited by XRATED
justin. weve used black crinkle paint. just the good quality VHT stuff. its grate and the spray nozles are to notch to now.
i wanted him to do black and red like mine but its all black. thoes cam covers are only on it for practability
Nice build up guys!
I gotta stop reading these Gts-t builds, makes me wana sell my 34 4 door and buy this
http://www.my105.com.au/classified.asp?id=12871
Edited by msports180
far out that's good value for money.
just been seam welding the buggery of the brake bracket. Surprisinly it's made a huge difference, once i throw some rhs at it, it'll be stiffer than my pants when i see your sister
Damn that looks awsome...
I just hope 6x 45mm tb's isn't to much tb for a little 20... either way it's going to sound awsome at 9k!!!
... yeah, these gts-t builds get's me thinking.
... overbore, shortskirt light weight pistons, lightweight rods, prepped crank and lots of ballancing. A little port work, some big ol cams, gtr itb's/inlet, ported stock manifold and small billet turbo. Super light flywheel and 4:11 gears.
Uuuuuber revvy.
    • I sense an out of control build thread coming up lololol. That 450kW goal will end up being 600 to 700kW LOL.
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
