By smooth i mean it doesnt look like it will take a finger off if you touched an edge...but you did just say you have been playing with it for a while....im just wonding the best way to cut and bend it to shape.
i do alot of work with 2mm and 3mm aluminium... i use a bandsaw to cut out most shapes, a die grinder to smooth the edges... than a deburring tool to take the corners off... they are the best things ever!!!
bout $20 and they'll last for ever.
there are double edged ones that do both sides in one go... but they are double the price.
give me 30k and ill have one built in under 6 months.
you realy want the series 2 because thats when you learn from mistakes and have already fixed all the dud ideas.
But bens is a series 2 for me as a lot of RnD of ideas has been done to my car.
funnily enough the targa car i looked after 2 years ago is for sale and its 15K and about half way developed. Bilstines haltech seats cage big brakes light wheels. just needs some of the finer things done.
Are you not better off putting the ECU on the transmission tunnel so it isnt getting kicked?
Any info on the one for sale for 15k?
At 30k i think they still represent decent value, provided its registered. I have alwasy joked with mates that if i had a clue how to i would make a one make R32 GTSt series...It would be a blast! :cool: But half the fun with this sort of car is really the build, doing things, everything just how you like it.
By the time the Nav foot rest is made it shouldn't be an issue, also with the sea so far back it's less likely to be kicked.
I've made sure i've kept paying the rego on mine, cbf putting it over the pits.
The 15k gtst is black, std body kit but with gtr alloy bonnet+grill. R32 GTR rims+brakes. Cage, extingisher, isolation switch..ect. Pretty sure it's got 2 sparco seats and harnesses. 3" exhaust and dump, Haltech E11v2
Edited by sav man
At 30k i think they still represent decent value, provided its registered. I have alwasy joked with mates that if i had a clue how to i would make a one make R32 GTSt series...It would be a blast! :P But half the fun with this sort of car is really the build, doing things, everything just how you like it.
after having worked on plenty of race cars with electrical dramas you get over trying to bend around roll cages so im putting it all in the one spot.
this was all designed with a specially built foot rest in mind.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
