I got the clutch on today, I suffered major retardation and put the flywheel on without the dust cover when the engine was out of the car (and torqued it up properly). So i had to pull the flywheel off, put the dust cover on, and put the flywheel on again. Good thing we saved the input shaft from the R33 when it blew the gearbox a few years ago, made aligning the clutch plate easy as. Big bad RB20 box will be going in tomorrow.
it's looking very likely to be from some block called rodger for the usa, 3 way adjustible. been asking a local tuner down here who has set the suspention up a few sucsesful Targa cars, and he recomended Penske and Ohlins over MCA. Because the Penske and Ohlins engeneers will valve to the specs you ask for, and Murry does what he wants. The shocks them selvs are much of a muchnes, appart from the Penske and Ohlens being lighter than the MCA (aloy vs steel).
Ohlins is way too dear, and if the valving needs to be modified i've got somone here who can say the valving needs to be changed to be xyz, i need somone who will try to get al close to xyz as possible.
Got the gearbox in today.
Kerry's car looks nice, but have passed since it isnt registerable. I would consider an unregistered car if it had more fruit in the way of brakes, wheels and suspension...but since it isnt registered will keep looking around.
oh yeah, forget about that. Being in tassie don't think twice about a car with SI, makes it hard in Vic i recon.
Kerry's car is damn quick
you talking about is white one with a td06?
Edited by sav man
more picatuoos
extra lights on the dash (indicators, highbeam, fuel low, altenator warning, abs warning)
Center switch panel
Moding Reo bar to fit N1 slots
Test fitting front end, still needs some sweeking to fit properly
I'm going to build a GMS GTR like air intake system (over top of radiator) next.
Edited by sav man
  • 3 weeks later...
I got myself a GTR fuel tank on the weekend. Originaly got it cause i thought it would be lighter (plastic vs steel), but when i put it beside the Gtst tank, i found it was a fair bit bigger. I just found a service manual which says the gtst has a 60l tank, i'd just assumed it was 72l like the GTR. Should be all set for some E85 action now.
Also fitted the steering wheel. Planning to get some alloy donuts to make the intercooler piping up next.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
