"I'll be converting the Crownie boxes to Alloy soon"
I'd love to see that magic trick... actually I'd like to see that magic trick in reverse! ha ha ha Alloy is cheaper than beer...
I cant wait to see the intake... If it works out well, I'm totally going to plagerise... ha ha
J.
  • 3 weeks later...
and in other news damo has been seen in the bushes around primary schools.
I've had a paint sceme in mind for a while now... and it's not painted like an animal, cars painted like animals look stupid, dad proved that.
Aw come on ben, not even something like this?
It's hard to get motivated when it's cold. I measured the suspension up today. Rear is easy to get good travel on. The front doesn't have alot of room for travel, you can only get about 60mm of travel at 345mm ride hight before the upper arm goes through the top of the tower. I'll reserch and play round with the ride hights on paper before i order the shocks
  • 4 weeks later...
Now got job security, so it's back into the car.
I've ordered my air filters for the airbox (2x Merc 600SL), and a 044 to pump E85 goodness around.
Damo wired in the ABS this weekend
I got 3/4 of a alloy donut and started my intercooler piping on the
It's almost ready to weld, I didn't take pics of the last section, but it just needs the ends tidied up, then off to the welder.
Also got the seat mounted
ben beat me to the pics but i thought id add some more pics to assist with other people wiring cars.
I use deutsch plugs for most of the bits that need plugs. these are by far the best plug you can buy. weather proof and higher current carrying capabilities than other similar sized plugs.
this is how they go together as such. this example is a plug for the ABS wheel sensor. the wire is 16gauge Mill spec is in PVC sleving which is my profered looming material. it makes the nicest neatest job of any loom but is a pain in the ass to do and probably adds 50% more time to any job.
next ois what i started with regarding all the ABS wiring
this shot shows that there is 2 looms mearging into one. a pice of heat-shrink is then slid over the top and once the 3 bits of PVC sleving are pulled into one the heat-shrink is then heated forming a seal between them all. On engine looms i use doubble walled heat-shrink that has a glue inside of it. when heated the glue goes runny and the heat-shrink pulls tight making some of the glue ooze out the end. this give an almost water tight seal and prevents the PVC sleving from pulling apart over time.
ill get a few more pics in the next week or so of the wiring into the switch pannel and fuse boxes.
I made the turbo side piping today. it's almost ready to weld up, but the pipe that damo supplied wasn't long enough...apparently this is a normal occerence. Another 50mm or so of pipe should fix it.
Got some sensors for the Haltech (oil temp, oil pressure, fuel pressure, exhaust temp)
Air box MKII with one of two filters in. pretty much a copy of the GMS one. Need to get some alloy and make it now, and then design the top 1/2.
Got the intercooler piping ready to weld today. Took ages to file all the joins so there wasn't any gaps... welder says it makes his life much easier.
I got a surge tank during the week too
  • 3 weeks later...
I got some more work done on the weekend
I cut the airbox out, and bent it up ready to weld.
I installed the Aero catches. They are are pain in the arse to install, but it's worth it when there in.
Also installed the belts, and finished suiding the interior
I got a heap of speedflow fittings for the surgetank setup.
I'm putting bulkhead connectors in the floor or the boot, will make it neat, and i won't have to worry about hoses rubbing on the hole in the floor
I'll get some hose tomorrow now i know the lengths, and then the setup will be done
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
