Time for some updates
I had this green puddle appearing under the car. Was time for a new water pump.
Out with the old
And in with the new
The airbox is now complete and installed.
I found that the coolent bleeder was blocked, so I had to remove the bleeder bar and blow it out with a air compressor. Unfortunatly I broke the barb that goes in it for the header tank, and that barb is all the is stopping the engine bay from being 100% complete. We also have mounted the canisters for the shocks.
The glass has also been installed. The car should be on the road early this week for some road tuning.
  • Nope 1
ME SO HORNY!!
love it mate. looking very nice now. I think you should let me borrow it for a while. i have too many cars so I'll happily give you a 2 for one deal for a quick swap. :) it's so nice. nothing un-necessary just all the right gear to go fast. it's probably my favourite car in this section at the moment. :)
Just went through the build for this, well done it looks awesome, cant wait to see some footage of it running.
What sort of power are you expecting from the motor? Interested to see how the rb20 highflow goes, i'm thinking of going that way on my rb20 to.
What paint did you use on the rockers?
So with AFMs being the nightmare they are, the radiator/intake beunbg reasonable solid mounted to the car, the AFM solid mounted to the radiator/intake...is there any concern over vibration and failing AFM? Given its on the inlet side i would be trying to throw some silicon either side to dampen any vibration it may be seeing
  • Like 1
I recon the AFM will handle it
Billit turbochargers high flowed it, was about $1600. I'll get a better idea of the responce when I tune it tomorrow. But the inital reaction is that it's pretty responsive on the limp around tune.
Looks great, that airbox is tops IF the AFM does break just tune without the AFM? :D but yeh looks like there is some flex in that blue piping anyway should be fine.
The engine paint looks nice as well I like it :) going to put some braces over the top?
I think the Haltech can live without a AFM ;)
Yeah i'll be getting some strut braces at some stage, just on the lookout for some cheap ones. possibly an engine dampner too, as I don't want to be replacing engine mounts all the time.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
