Top job at the railway crossing/dip think you were one out of only three cars that kept it pinned through there and the only car that produced sparks :thumbsup:
pics of said sparks? Gotta thank the Penske's for that, they handle big bumps like that with no problems
Now the car has been in a big event, I thought I better post some findings about the car.
1) You need a decent sump! From the datalogs, the oil pressure will constantly drop into the 0-5psi range under heavy braking (cornering and acceleration forces don't bother it). It only does it for less than a second at a time, but as we found out, you're driving a time bomb.
2) Spending money on good shocks was worth every cent. We probably only tuned the car 70%-80% of what it could be, but the way the shocks handeled the big bumps really surprised me. Coming from the Bilsteins in the GT-R (which I was happy with), it was in another leage.
3) airbox and radiator worked like a dream. Intake temps were only 10-15deg above ambient. And the coolent never got above 85deg on a stage, you could see the thermostat opening and closing from the datalogs. As the temp woudl go from 85 down to 78, then back up to 85 2-3 times over a 30km stage.
4) Fancy dash was worth the money. The data from the logs was invaluable during the event, and I found the dash clear and easy to read during the stages. If you're racing you will spend just as much money on gauges as a dash.
5) ITB have plusses and minuses. They have given the same effect as bigger cams, with a loss of power down low, but it does keep the power going right to 8000rpm (and beyond if you had the turbo for it). I personly hate the throttle responce from the std 20, I think it makes gear changes slower (waiting for the engine to rev down so the box will engage the next gear), and it makes the engine feel like it's attached directly to your foot. I'm going to try some cam gears, and hopfully that will give me some responce back..... but if I didn't need to drop the rev's back to 7000rpm from 8000rpm, I don't think it would have been as much of an issue. I don't think I'd recomend it for other people, but I personly think they improved the entire package.
6) catch can design needs more thought than just hooking a single tank up. Constant high rpm needs oil restrictors, oil air separator, thicker oil, and a return to the sump.
I'm suprised re the oil surge Benny. Mine did about 10,000klm of competetive driving before a big end went, but I'm blaming that on running 30 odd 100% pace laps in a Qld summer without an oil cooler! lol
Do.did you run a litre overfull?
I run it to the top of the hump of the dip stick, I think it's about a litre if not more. It seems all 20's will eventually run a bearing, just not as soon as mine.
We pulled the engine down last night, and bearing 3 was the one that died.
Yeah ABS works well, it's 4 channel unit out of a VY Commodore with traction control (tc isn't hooked up though). Idely it'd be nicer if it was slightly less sensitive, but you only really notice that on a circuit.
thought id post up some pics we got before and during targa
the day ben killed the engine.
This nissan flag poped up at least once every day during the event and was usualy acompanied with a toot of the horn and a bit of drift.
Stopped in queenstown. just one of the many stops through out targa
checking results. Gotta keep on your game
Belt up bitches
And almost to the finish line. Pre finish team meet.
5 and a bit days of racing the car pulled up pretty good.
Im pretty confident you will see this team about again.
Did the service crew take the pic of the Nissan flag?
didn't upload the pics of the car when it was waiting on Bradshaw bridge to tackle Arrowsmith.
I've got a new high responce bottom end ready to go. Just need to bash some restrictors into it, and sort a sump out. ASR looks the go for the sump.
    • If you mean the alarm immobiliser; theyre internal to the alarm itself which makes that difficult; I couldnt even see where he put it; its not in the same place as last time; but with all black wiring it might be very challenging to trace  I had someone turn the key for me as I know it only primes for a couple of seconds As my post above; I am getting no voltage to the pump at all; but I am testing continuity of the power line (SB) from the pump plug to the relay fine. As well as the negative from the pump plug to a 12V constant.    Yeah; he blammed the no start on a bad battery; said I needed to get a new battery and it'll start. Turns out the battery drained because the tail lights had been on for half the day during the install (the rubber cushion on the brake switch gave out while he was testing it as I have a picture of the car from that morning with the tail lights off..i've replaced that). The battery was turning over the engine just fine for a long time; but got low since lights were draining it so it was too low to test a start after he finished. I bought a new one on his advice...$250 wasted. My original battery charged up just fine and is healthy.    It was running perfectly fine when I messed up the old alarm (programmed out the remotes). He couldnt start it after removing the old alarm; my assumption is that when he unhooked it; he didnt bridge the circuit back when trying to start it. Its always been perfectly fine. The ECU swap and pump were 2 years ago. It's never missed a beat in that time.
    • This is a big issue for me without the diff. I just have zero drive from the passenger side when drivers side has no traction. Bec's parents place has a crazy steep driveway with odd camber and I have never been able to get up. My bro-in-law's 130i with an (unknown brand) LSD gets up fine as does their dad's Hiace. My car stays at the bottom. We have other odd camber roads around here as we're elevated a bit and if it's raining I can get totally stuck around some hairpins.
    • Yeah, I am super excited for this.
    • Was the car running before he touched the car?
