na just a good gated sump from asr. i'm not overly thrilled about the extra weight from the extra 2l of oil, so the idea of all the extra weight for 12l of oil and the lines and shit for a dry sump don't make it a good sell..... and i'm being a giant jew.
Funds is the only thing that is stopping it from going again. I've got the new bottom end there ready to go, just need a bash some restrictors in it, and buy a sump.
na, still hydro lifters. Only reason I can see a need for solid lifters would be for bigger cams. But I can't see why you'd ever put bigger cams on a 20, as they came over cammed from the factory.
boost and revs=full catch can. There is a guy down here who circuit races a std RB20, and he won't rev past 6500 with the same boost as me (23psi) because he fills the catch can. The amount of oil that is coming out can't be fixed with catch tank tricks. And for the $30-$40 it's going to cost I thought I might as do it. I'm using SydneyKids specs.
had 263rwkw at the start of the week, 200 - 220rwkw on the new engine (depending on the heat of the engine), then take 5psi of boost off from day 4 onwoods...180kwrw??
E85 did give it a good kick in the pants though. I only tuned the 98ron map on the road, so I don't have a power figure for it.
Edited by sav man
I was running 24psi and 8000rpm out of my RB20 for a fair while running about the same power as you...
Not a single drop in my catch can and that car got belted the f**k out of it on a stock motor, so maybe the motor is a little loose or tired?
I'm at a bit of a loss to be honest.
I'm struggling to understand how .2 bar can make such a difference. Mine doesn't pump into the catch can either, and I'm not exactly easy on it. Even after 5 days of targa there was still no sign that there'd been oil in the can at any time (I have it so it self recovers if it does pump into the can)...... Hell, #1 piston was half melted away and it still wasn't pumping oil! lol
I'm putting mine back together stock internally, and will be interested to see if a little more boost tips it over the edge.
what thickness oil do you run? I was using Motul 8100 5w-40, but i'm going to goto 25w60. Neither engine was compression tested or leak down tested.
The N1 never has this issue, even with 25psi and a big nitto pump.
Edited by sav man
Yeh Castrol for all RB20 crate motors :) I have only ever blown oil when there was plenty of limiter action. Bump the limiter a few rpm so i never hit it and no problem. Even the breathing on limiter isnt a common thing, but its about as good as i can do for a reason for the 2-3 times it has happened
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
