regardless of gauges or no gauges we have simply offered up some free info that has taken time and money to get. we used 2 different examples ect ect. take from it what you like. we will take that its simply better not to have to change engines the night before or during events (which is when we have had to do the last 2) and if your half capible a simple mod to the sump will stop that.
ironicly - My old drift team mate spun a bearing the first time he drifted after fitting an oil cooler. i blame the cooler 100%
You saying the cooler reduced the oil pressure to much?....
Woo aren't you installing one... Better touch wood!
The workshop putting together an external oil pump kit for me strongly advised against using an external filter block due to the poor design. Can't say I paid it much thought at the time given the number of folks running them but these guys do build a lot of race/drift motors.
Hypercry?
By external filter block you mean the block adapter or remote oil filter kit?
Also keen to know thoughts on the oil cooler causing failure!
I've got one coming with a built in thermostat
I think the comment was made with sarcasm... The same way the rest of us were taking the piss and blaming the gauges for wrecking motors...
I've been a bit slack cause it's been too cold. But the replacment engine is pulled down to install the restrictor, and mod the sump.
We had a high pitched squeel all event. We knew it was a boost leak, but considering everthing else we couldn't be bothered. After I pulled the car appart, I found the source of the leak. I had put a incorectly sized bolt clamp on, and it didn't seal evenly.
still considering it, i'd like to have a good look at one of them. But Damo and I have worked out how to VVT a normal RB20 head, just would come down to funds, and if this new engine needs it.
Did you consider a secret handshake V-Cam RB20 :) or are there elegibility problems with running a later model head, series of engine?
i had a bit of a think tank and dragged a coupple of old heads and bits up from storage and worked out that if the gains were there to be had it was easy enough to make vvt work on a rb20 head. without modding the head. i took a bit of insperation from the HKS V-Cam and sussed it all out. i supose people just dont see the point developing rb20 engines but for us having to fit within engine size rules we have/ want to think outside the square.
i think the whole project is just bringing good ideas from everywhere and putting them on one car.
the super f1 spec engine is has actualy suprised us both in its designe.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
