I took the caster rods out last night, they are rooted. The steel sleave in the drivers side bush just falls out, and the passengers side has a 2mm gap all the way round. We thought the bushes were stuffed, but didn't realise how bad they were.
How will you adjust if you use the genuine ones mate?
Not adjust them, I think them not moving is better than being able to adjust them. When Berry was down a few years ago, he was saying how much better new genunine bushes are then whiteline etc
  • 1 month later...
time for a big picture update. Engine is almost ready to roll
ARP Studs installed
Head back where it belongs
Damo and I took to the exhaust ports with a die grinder.
Most of the stuff is bolted back up to it now, and the block in nice and silver.
Aim is to have it ready for the Legerwood Lane hillclimb on the 29th.
I've blocked one of the oil galleries, and fitted a 1.3mm restrictor to the other one (as per sydney kids guide). Not running a external return from the head at this stage, as most poeple that have done it found it doesn't drain very well. I have also put rb26 cam covers on to help the oil/air separation.
  • 3 weeks later...
i'm on the hunt for some 22mm hose for the breathers now
Its not 22mm but it will fit the 26 breathers, it what I ran on mine.
http://www.xtremeautoparts.com.au/shop/pc/viewPrd.asp?idproduct=160&idcategory=107
You guys doing targa again this year?
Yep entry is already in.
How easy does it stretch? ie does it go on and off easy, so you can work on the car?
    • I was 99% sure the standard one is long enough to get there, you might just have to change the throttle orientation. If not, I remember someone having used an r31 cable instead, but that is probably harder to find than r33 by now...
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
