The car got it's first outing since Targa yesterday at the MSCT club day at Symmons Plains. Dropped my PB down to 60.1 secs. But only got 5 laps in for the day, as the coolent header tank spring a leak and wouldn't hold pressure. Radiators Plus in Launceston tried to repair it, but because of the good Chinese design it couldn't be fixed. I'm going to replace it with a Greddy one.
im pretty sure Ben just broke the car so i couldnt drive it.
non the less it was probably the most impressive test day so far with the car showing stacks of potential.
it was also the first R&D test for the new alternator design. it didnt fail like the Chinese header tank so it must be ok.
  • 1 month later...
Another event, and another niggling problem. I got a single run in on the Ledgerwood lane hillclimb, and then the oil filter started leaking. Looks like it got pinched, and decided to start leaking. Luckily the car didn't run out of oil. Before the event I bought 2 lengths of dowl from Bunnings, and gave it it's first wheel alignment in 2 years.
But in good news the car was quick straight out of the box, and was only 0.2 secs behind Greg Garwood in his 997 GT2 Porsche Targa car
  • 4 weeks later...
This week I upgraded the oil cooler to a substantially larger one
I also changed the lifters over, cause I'm sick of them rattling.
Today was the state supersprint championships. I ended up 3rd overall, and 1st in class. I was only behind a 500rwkw supra, and 400awkw evo....But I once again only got a single run in. On the second last corner of the last lap, a hose blew off my oil cooler. I used proper earls pushlock fittings which are rated to 400psi, and the fittings have done a Targa, so it's a mystery why it came off. But the engine is dead
ahh a bit late to mention, but I've had trouble twice with pushlock fittings. It may be that they are perfectly reliable when fitted correctly, if so I have made mistakes 2/3 times I have used them...way too low a success rate for me. 1 ps cooler line on the race car (has been OK for years since when I added hose clamps :/ and 1 failure on the turbo oil feed on the tow car, replaced it with braided with proper hose ends
spend up big on real fittings IMHO, even if you need to get the damn things made to length
sorry to hear about it's death, you are catching up with me. leave it in the corner to gather dust for 3 months until the itch returns
Yep it was Rodgers. Sherriff tuned it during the week, 497rwkw unopened 2j with cams and turbo.
I've used push lock a fair bit, all my fuel system is done with it, and i've done other coolers with it. But I've always used speedflow fittings in the past, and mine was the only time i've used earls ones. I don't really rate them. I hate stainless braid with a burning hate, it's shit to work with, and it rubs through anything it goes near.
  • Like 1
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
    • Continental have consistently beaten the absolute shit out of every other performance tyre in Wet/Damp/Cold conditions and give up a little bit of time (half a second at most) in the dry. Almost like it's engineered for German conditions or something. I'd def give those a try.
