The car got it's first outing since Targa yesterday at the MSCT club day at Symmons Plains. Dropped my PB down to 60.1 secs. But only got 5 laps in for the day, as the coolent header tank spring a leak and wouldn't hold pressure. Radiators Plus in Launceston tried to repair it, but because of the good Chinese design it couldn't be fixed. I'm going to replace it with a Greddy one.
im pretty sure Ben just broke the car so i couldnt drive it.
non the less it was probably the most impressive test day so far with the car showing stacks of potential.
it was also the first R&D test for the new alternator design. it didnt fail like the Chinese header tank so it must be ok.
  • 1 month later...
Another event, and another niggling problem. I got a single run in on the Ledgerwood lane hillclimb, and then the oil filter started leaking. Looks like it got pinched, and decided to start leaking. Luckily the car didn't run out of oil. Before the event I bought 2 lengths of dowl from Bunnings, and gave it it's first wheel alignment in 2 years.
But in good news the car was quick straight out of the box, and was only 0.2 secs behind Greg Garwood in his 997 GT2 Porsche Targa car
  • 4 weeks later...
This week I upgraded the oil cooler to a substantially larger one
I also changed the lifters over, cause I'm sick of them rattling.
Today was the state supersprint championships. I ended up 3rd overall, and 1st in class. I was only behind a 500rwkw supra, and 400awkw evo....But I once again only got a single run in. On the second last corner of the last lap, a hose blew off my oil cooler. I used proper earls pushlock fittings which are rated to 400psi, and the fittings have done a Targa, so it's a mystery why it came off. But the engine is dead
ahh a bit late to mention, but I've had trouble twice with pushlock fittings. It may be that they are perfectly reliable when fitted correctly, if so I have made mistakes 2/3 times I have used them...way too low a success rate for me. 1 ps cooler line on the race car (has been OK for years since when I added hose clamps :/ and 1 failure on the turbo oil feed on the tow car, replaced it with braided with proper hose ends
spend up big on real fittings IMHO, even if you need to get the damn things made to length
sorry to hear about it's death, you are catching up with me. leave it in the corner to gather dust for 3 months until the itch returns
Yep it was Rodgers. Sherriff tuned it during the week, 497rwkw unopened 2j with cams and turbo.
I've used push lock a fair bit, all my fuel system is done with it, and i've done other coolers with it. But I've always used speedflow fittings in the past, and mine was the only time i've used earls ones. I don't really rate them. I hate stainless braid with a burning hate, it's shit to work with, and it rubs through anything it goes near.
  • Like 1
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
