The car got it's first outing since Targa yesterday at the MSCT club day at Symmons Plains. Dropped my PB down to 60.1 secs. But only got 5 laps in for the day, as the coolent header tank spring a leak and wouldn't hold pressure. Radiators Plus in Launceston tried to repair it, but because of the good Chinese design it couldn't be fixed. I'm going to replace it with a Greddy one.
im pretty sure Ben just broke the car so i couldnt drive it.
non the less it was probably the most impressive test day so far with the car showing stacks of potential.
it was also the first R&D test for the new alternator design. it didnt fail like the Chinese header tank so it must be ok.
  • 1 month later...
Another event, and another niggling problem. I got a single run in on the Ledgerwood lane hillclimb, and then the oil filter started leaking. Looks like it got pinched, and decided to start leaking. Luckily the car didn't run out of oil. Before the event I bought 2 lengths of dowl from Bunnings, and gave it it's first wheel alignment in 2 years.
But in good news the car was quick straight out of the box, and was only 0.2 secs behind Greg Garwood in his 997 GT2 Porsche Targa car
  • 4 weeks later...
This week I upgraded the oil cooler to a substantially larger one
I also changed the lifters over, cause I'm sick of them rattling.
Today was the state supersprint championships. I ended up 3rd overall, and 1st in class. I was only behind a 500rwkw supra, and 400awkw evo....But I once again only got a single run in. On the second last corner of the last lap, a hose blew off my oil cooler. I used proper earls pushlock fittings which are rated to 400psi, and the fittings have done a Targa, so it's a mystery why it came off. But the engine is dead
ahh a bit late to mention, but I've had trouble twice with pushlock fittings. It may be that they are perfectly reliable when fitted correctly, if so I have made mistakes 2/3 times I have used them...way too low a success rate for me. 1 ps cooler line on the race car (has been OK for years since when I added hose clamps :/ and 1 failure on the turbo oil feed on the tow car, replaced it with braided with proper hose ends
spend up big on real fittings IMHO, even if you need to get the damn things made to length
sorry to hear about it's death, you are catching up with me. leave it in the corner to gather dust for 3 months until the itch returns
Yep it was Rodgers. Sherriff tuned it during the week, 497rwkw unopened 2j with cams and turbo.
I've used push lock a fair bit, all my fuel system is done with it, and i've done other coolers with it. But I've always used speedflow fittings in the past, and mine was the only time i've used earls ones. I don't really rate them. I hate stainless braid with a burning hate, it's shit to work with, and it rubs through anything it goes near.
  • Like 1
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
