just tell her theres plenty more cash yet to go rolling into the Stagea !
and no she cant have a luis vetton handbag
Im at the stage now where I want to drop in the 480cc injectors, but I want a better piggyback
currently remap ecu + safc/sitc, Im thinking emanage ultimate or 2ndhand ebay special, like wolf3d
remap and wolf3d probably would work well tbh.............
  • Replies 74
hhhhhmmmmmm!!!!
Wife just found out the I have received and already spent my tax return...........there was a very long pause on the phone followed by " I am to pissed off to talk to you right now.....we will chat when I get home"
Options guys.....HELP!!!!!!
Option one: Get drunk before I get home!
Option two: Don't go home
Option three: Flowers and chocolate
Option four: Find new wife
HELP.....please!!!!! :P
option five: never return, ever.
on a completely unrelated topic, craig is looking for a rental place in sydney :P
I'll rent you our spare bed at our house. LOL
Huge upside
* close to work
* Rent pays for mods on my car
* Don't have to see your wife till the weekend
Just tell he the commute is getting you down and you need to stay local. hehehehe
hhhhhmmmmmm!!!!
Maybe you could always hint that her tax return could have been used instead?
It's fantastic to see that some guys are pushing the boundaries on M35 mods. I would be keen to do all these mods as well if I didnt spend all my damn tax return on the GT-R, but mind you, over 300kw at all fours is so thrilling..
It makes you do the he he he.. ohhh.. every time you drive. i miss driving the gtr, i want my motor back!!
Looking at the dyno sheet, you seem to have a big flat spot around 3700-4500rpm - due to the big dip in boost pressure. If you were able to improve boost and maybe hold it at 18 you'd see a much better top end result. Not sure how possible that is.
In theory if the boost was set to 15psi and the boost controller was able to hold it there constant, you'd probably see the same kw figure.
yeh....the dyno guy wants me to put an electronic boost controller to fix the flat spot(the go on the dyno again :P ).......wont get me much more KW's top end but it will cure the dip and bring the boost on quicker
yeh....the dyno guy wants me to put an electronic boost controller to fix the flat spot(the go on the dyno again :down: ).......wont get me much more KW's top end but it will cure the dip and bring the boost on quicker
Craig, Ive got and electronic boost controller on mine and it still drops off boost a little in the top end I think its because the turbo is too small and doesnt flow enough at high rev's
That is more than likely because of the intercooler.....we were having to have a 10 minute break between each run to help the car cool down properly.....the electronic boost controller isn't going to get me anymore top end hp but it will help me control the dip and get a nice flat line.
P.S. The only reason I went to 18PSI(my turbo is good for 22) is because I wanted the magic 200kw's.....16PSI showed me 196.2KW....17psi 199.99KW....lol. If I do the right sized intercooler I might(might) get up to 210 or above.
Edited by Jetwreck
just make sure the engine can take that sort of boost! dont wanna go bang! not yet anyway haha
Standard ECU will put the car into limp mode as soon as it detects 20PSI....motor can handle it :D ....and if it cannot......the next motor will lol.......there always next year tax return :P
what you gonna drive till next year if you pop it now :P
id really be interested to see how much boost they CAN safely take. if nissan havent changed much, then 20psi is probably possible assuming the tune is done well
Normally the boost will build up and then drop away slowly as you approach the red line. In this case the boost is dropping back sharply very early in the revs (around 3600rpm) which to me doesn't look normal. Maybe it is the turbo not being able to keep up but I'd say its the boost controller.
It will usually taper off a bit towards the top end. When I put the highflow on my last stagea it dropped by 2psi by the time it got to the red line, but it was a gradual decrease.
On the topic of coolers,
what would you guys want? something larger in size? or the stock size but a better core?
i'm guessing it will be a fairly custom job, what would be the easiest/best thing to do?
PWR custom "Aero 2".
I have only a rough design which should fit nicely (haven't made up a cardboard unit to see if it will fit).
Also need to have appropriate supports added... but for now this is what I am looking at
I want to go to 3" piping (thanks again Scotty for the BOV mounting intake pipe :P ) and have decided to make it the same depth as the OE unit as Iam trying to get as much volume as possible while keeping it as unobtrusive as I can.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
