Hello there,
I came across these videos.
It shows an R34 upgrade using larger exhaust, intercooler, and finally boost level (boost controller) upgrade.
After each mod it goes to the dyno, results are shown.
I found this quite interesting, so have a peek:
Skyline R34 Stage 1 Video/Dyno
You need Windows Media Player and a good internet connection.
I was tired of rubber stamp sized videos, so I encoded the video in a decent size.
Cheers :P
Edited by Torques
https://www.sau.com.au/forums/topic/282678-r34-gtst-stage-1-tuning-video/
did the stock turbo blow up at 12psi ?? I've been running my stock GTT at approx. 12 psi for more than a year now hmm... Well I don't really hit 12psi that often as I rarely gun it above 5000rpm but still, a bit of a worry especially since that crap can end up inside the engine and not just the cat..
  • 2 months later...
Quite like videos like this.
Yep, far too less of this kind around.
It's no nonsense with proper before and after dynos ...
I have updated the page for the video, now showing 2 more stages ... however there seems to be some kind of network problem.
The sound stutters at times ... I might have to upload it again.
R34 GTT Stages
Edited by Torques
Nice Post, realli helped me Tuning my GT-T; jus a few annoying questions =p, What Exhaust Manifold Did the HPI car use? and not sure they tell you in the hpi video but how did u get those aftermarket gauges to fit in the stock center guage pod!?!? need to replace mine =D. THanx and Thanx heaps for teh vids!
R34 GTT Stages
Sound was good on Stage 3 , but the video was horrible, like 1 frame a second :) Cleaned up at points.. but not very nice to watch :P
Same with Stage 4. Video is really bad but sound was good. The picture is clear, but not smooth, ya know.
Maybe try again, im knee to see.
Edited by gotRICE?
Hello there ...
I have made a new attempt at the videos.
It's not perfect but seems to be working (at least on my side of the globe:)).
Please let me know if you have any stutter or playback issues.
It's best viewed with Internet Explorer it seems .. (sorry about that)
Here's the link:
R33 GTST /34 GTT And Related
Hello there ...
Here's the link:
They look good on Firefox for me.
Great videos.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
